It is currently Sun Aug 17, 2025 1:46 pm
PostPosted: Mon Jul 08, 2013 7:59 pm
Good evening
So I had no key for my boot handle and I purchased matching locks for the boot and drivers door for my 69 mini k.
The only problem is the old barrel doesn't want to come out of the handle.
Is there a trick to it, or could it be stuck from corrosion, etc?
Thanks
PostPosted: Mon Jul 08, 2013 9:38 pm
There is a pin that holds the barrel in. Have you knocked this part out?
PostPosted: Mon Jul 08, 2013 9:42 pm
The Mini King
[quote="talfox"]Good evening
Thanks[/quotes
if You remove the Chrome bezel from the handle, You should find a small brass pin in the tubular part of the handle Knock that Out and You should be able to remove the barrel
PostPosted: Tue Jul 09, 2013 9:06 pm
thanks bubba and john.
i tried the pin but it wouldn't budge.
i ended up drilling it out.it was corroded.
fit replacement one's . all good now. thanks
Users browsing this forum: Bing [Bot] and 381 guests
