It is currently Sat Jun 21, 2025 8:59 am
 Post subject: Cleaning Fuel Tanks
PostPosted: Mon Jul 08, 2013 7:08 pm
Die Die Die!!
does anyone have a remedy for cleaning fuel tanks out ?
or is the only way to get a POR15 Fuel Tank Repair Kit ?
as mine is like varnish - See below
Nick
PostPosted: Mon Jul 08, 2013 7:09 pm
vinegar
PostPosted: Mon Jul 08, 2013 7:13 pm
Die Die Die!!
any particular type ?
PostPosted: Mon Jul 08, 2013 7:49 pm
balsamic vinegar
PostPosted: Mon Jul 08, 2013 9:26 pm
I used a handful of bi-carb soda shook it all around inside the tank then threw in a cup or two white vinegar, fizzed up great and a lot of crap came out. Repeated the process a few times. All good.
 Post subject: Fuel Tank Cleaning
PostPosted: Tue Jul 09, 2013 1:36 pm
Location: MinisintheGong [Somewhere on the South Coast]
And what is everyone's thoughts on an overnight stand with diesel in the tank to see if thre are any seam leaks?
..still waiting for the Italian Job sequel to see if the bus went down :-) :-)
PostPosted: Tue Jul 09, 2013 2:53 pm
+1 for the bicarb and vinegar. Needs a bit of agitation with a long handled brush and a lot of shaking but you get most of the gum out. Just use the Coles smart buy vinegar or the cleaning vinegar. The POR reline stuff is good but follow the instructions to a tee otherwise you will be cleaning your fuel system weekly for years!
Hooroo
Rob Forsyth
Miniot!!
