Changing locks on my boot handle https://www.ausmini.com/forums/viewtopic.php?f=2&t=82033 |
Author: | talfox [ Mon Jul 08, 2013 7:59 pm ] |
Post subject: | Changing locks on my boot handle |
Good evening So I had no key for my boot handle and I purchased matching locks for the boot and drivers door for my 69 mini k. The only problem is the old barrel doesn't want to come out of the handle. Is there a trick to it, or could it be stuck from corrosion, etc? Thanks |
Author: | Bubbacluby [ Mon Jul 08, 2013 9:38 pm ] |
There is a pin that holds the barrel in. Have you knocked this part out? |
Author: | John Smidt [ Mon Jul 08, 2013 9:42 pm ] |
Post subject: | Re: Changing locks on my boot handle |
[quote="talfox"]Good evening So I had no key for my boot handle and I purchased matching locks for the boot and drivers door for my 69 mini k. The only problem is the old barrel doesn't want to come out of the handle. Is there a trick to it, or could it be stuck from corrosion, etc? Thanks[/quotes if You remove the Chrome bezel from the handle, You should find a small brass pin in the tubular part of the handle Knock that Out and You should be able to remove the barrel |
Author: | talfox [ Tue Jul 09, 2013 9:06 pm ] |
thanks bubba and john. i tried the pin but it wouldn't budge. i ended up drilling it out.it was corroded. fit replacement one's . all good now. thanks |
