A couple of door questions... https://www.ausmini.com/forums/viewtopic.php?f=2&t=82043 |
Author: | Thorlek [ Tue Jul 09, 2013 3:41 pm ] |
Post subject: | A couple of door questions... |
Hi All, just a couple of quick questions before i put my doors back together... How many of the little 'S' clips should be used to attach the chrome and rubber/rubber to the door, im guessing i need around 3 - 4 on both inside and out on both sides... so like 12 or 16 of the clips??? Are the standard door trim clips the way to go when attaching door cards? I was thinking it might be better to use 2 or maybe 4 stainless screws, or maybe just using the standard christmas tree clips? and finally... are clip on mirrors on the A Pillar or Quarter Light any good (visibility wise)? or am i better off screwing a mirror into the door skin? (I have no mirrors or screw holes atm so can go with any option) Thanks! |
Author: | John Smidt [ Tue Jul 09, 2013 4:03 pm ] |
Post subject: | Re: A couple of door questions... |
Thorlek wrote: Hi All,
just a couple of quick questions before i put my doors back together... How many of the little 'S' clips should be used to attach the chrome and rubber/rubber to the door, im guessing i need around 3 - 4 on both inside and out on both sides... so like 12 or 16 of the clips??? The outer clip is 34G939 4 per door the inner clip that holds the felt and the chrome strip is a totally different clip HYA1512, 4 Per door ( although some people use the 34G939 for this ) Are the standard door trim clips the way to go when attaching door cards? I was thinking it might be better to use 2 or maybe 4 stainless screws, or maybe just using the standard christmas tree clips? Use New clips and new sockets and it will work fine, Clip HYA1860 Socket 14A8094 and finally... are clip on mirrors on the A Pillar or Quarter Light any good (visibility wise)? or am i better off screwing a mirror into the door skin? (I have no mirrors or screw holes atm so can go with any option) I My opinion the mirrors that screwed to the door is a better option Thanks! |
Author: | Bubbacluby [ Tue Jul 09, 2013 6:07 pm ] |
You probably got those part numbers from the top of your head too didn't you John ![]() If only I could remember stuff like this...... |
Author: | winabbey [ Tue Jul 09, 2013 6:27 pm ] |
Bubbacluby wrote: You probably got those part numbers from the top of your head too didn't you John
![]() Not only that, he probably had a handful of each type of clip in his pocket. ![]() |
Author: | Thorlek [ Fri Jul 12, 2013 7:01 pm ] |
John Smidt wrote: The outer clip is 34G939 4 per door
does the chrome strip also get held on by this? do you just put this clip onto the door, put the rubber into the U on the inside... and the chrome over the bit thats on the door? or do i need another clip for the chrome? also, is there a gasket/rubber to put between the door panel and the outside handle? thanks! |
