It is currently Sun Aug 17, 2025 9:25 pm
 Post subject: Rover mini air con kit
PostPosted: Fri Jul 12, 2013 10:39 am
Just wondering how common it would be or a good place to source a rover mini air con kit?
I was thinking it would probably be suitable to use in a datsun powered morris minor seeing as they'd put out about the same amount of power..
Tom
PostPosted: Fri Jul 12, 2013 12:10 pm
Tom
It would probably be easier to find a 120Y or Sunny kit and retrofit that. Or even one of the countless "Vintage Air" type under-dash units available.
A Rover Mini kit is not going to fit your engine, engine bay or under your dashboard, so there would be a lot of custom work required. Plus they are hard to find.
Brett.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jul 12, 2013 1:16 pm
Not only that, spare parts can be tricky to get.
I had to get half my hard pipework changed from SAE #5 to SAE #6.
If you want a cheap setup I'd adapt something more common like from an old rolla or excel .
Users browsing this forum: Sahig131 and 350 guests
