Rover mini air con kit https://www.ausmini.com/forums/viewtopic.php?f=2&t=82069 |
Author: | thomen [ Fri Jul 12, 2013 10:39 am ] |
Post subject: | Rover mini air con kit |
Just wondering how common it would be or a good place to source a rover mini air con kit? I was thinking it would probably be suitable to use in a datsun powered morris minor seeing as they'd put out about the same amount of power.. Cheers, Tom |
Author: | bnicho [ Fri Jul 12, 2013 12:10 pm ] |
Post subject: | Re: Rover mini air con kit |
thomen wrote: Just wondering how common it would be or a good place to source a rover mini air con kit?
I was thinking it would probably be suitable to use in a datsun powered morris minor seeing as they'd put out about the same amount of power.. Cheers, Tom It would probably be easier to find a 120Y or Sunny kit and retrofit that. Or even one of the countless "Vintage Air" type under-dash units available. A Rover Mini kit is not going to fit your engine, engine bay or under your dashboard, so there would be a lot of custom work required. Plus they are hard to find. Cheers, Brett. |
Author: | Harley [ Fri Jul 12, 2013 1:16 pm ] |
Not only that, spare parts can be tricky to get. I had to get half my hard pipework changed from SAE #5 to SAE #6. If you want a cheap setup I'd adapt something more common like from an old rolla or excel . |
