Recognise these pistons and... carbon removal.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82098
Page 1 of 2
Author:  1275LS [ Sun Jul 14, 2013 10:59 pm ]
Post subject:  Recognise these pistons and... carbon removal.
A bit hard to guess but does anyone recognise this make of piston from the photo below? They are not an arc dish rather a straight taper to a flat dish. At a smidge over 72mm I am assuming this makes it 60thou over. Do we calculate the capacity including the chamber and dish or the stroke capacity?
Also can anyone suggest a good carbon removal strategy. I'd like to clean off the pistons before I put the head back.
I will get it rebuilt at a later date but for now just need it back on the road.
Author:  Boostedmini [ Mon Jul 15, 2013 7:57 am ]
A can of coke over a couple of days will work well.
im sure there will be more carbon in the ring lands also, it looks pretty average, why was th head removed?
Author:  TheMiniMan [ Mon Jul 15, 2013 8:39 am ]
look like ACL pistons to me
Author:  drmini in aust [ Mon Jul 15, 2013 8:41 am ]
Ditto.
Author:  Kennomini [ Mon Jul 15, 2013 6:32 pm ]
Correct me, but aint ALC a slightly cheaper brand :?:
Author:  TheMiniMan [ Mon Jul 15, 2013 7:56 pm ]
ALC ? i havn`t heard of ALC :-)
But yes ACL (repco) are very good value for money if that`s what you mean?
Author:  1275LS [ Mon Jul 15, 2013 9:48 pm ]
Head gasket was leaking into the number 2 cylinder and blowing steam.
The head is getting rebuilt at the moment.
The rest will get a rebuild in the future but for now I will just put it back together after cleaning the carbon out.
And I wont be putting a can of coke anywhere near the sleeves.
Author:  Kennomini [ Mon Jul 15, 2013 10:05 pm ]
I was actually refering to quality but by the sounds of it they are still a reasonable piston, good to know.
Author:  drmini in aust [ Mon Jul 15, 2013 10:22 pm ]
Can you still get ACL pistons new? Their piston plant in Melbourne got sold to Mahle to make GMH's pistons only, I heard. Then recently I heard Mahle had closed it and taken the equipment to Germany or somewhere.
Author:  TheMiniMan [ Tue Jul 16, 2013 8:35 am ]
not sure, i havn`t bought them for a while
toto & riteway & ACL were the cheapest for years but havn`t seen them avaliable for a long while now,,, not that i was looking :-)
Author:  esskay64 [ Tue Jul 16, 2013 1:39 pm ]
Is that a crack in the block in the lower left, heading towards the cylinder liner? :?
Author:  Boostedmini [ Tue Jul 16, 2013 2:11 pm ]
do all Cylinders look the same condition?
if your not going to rebuild it i would wipe out and blow out as much as you can. thought with that amount of carbon there i would say its going to need a rebuild in the near future..
Author:  mini_mad_matt [ Tue Jul 16, 2013 5:03 pm ]
Just looks like headgasket half left on the block to me
Author:  TheMiniMan [ Tue Jul 16, 2013 9:37 pm ]
funny as & excellent at the same time :-)
funny as :-)
sorry,,, but for everyone else,,, there`s a tiny patch where the "slight" blow started, (on the right side of the left cyl in the pic) then it`s progressed & it was actually always going to happen cause you can see the "Narrowing" of the surface in the gasket mark yeah?,,,
& Mattys seen it before most have,,, but i caught that from Mattys little cute pick-up > :-)
well done young fella
Author:  1275LS [ Wed Jul 17, 2013 12:22 am ]
Yep head gasket remnants - no crack. Otherwise I would be looking for a replacement and not rebuilding the head. Will be cleaning up this weekend and will post some photos of a relatively shiny block. Now about that carbon removal strategy.. Any further suggestions?
Aside from being covered in gunk it all looks ok. The sleeves are pretty tidy atm so that's why I am happy to leave it. I have talked about doing the motor with Matt prior to this and one of these days I'll get around to it.
Right now I just need to get it back in running order so the family can use the second car again. Besides which I am getting withdrawal symptoms.
So given some time this weekend it is LH engine mount getting replaced and the top of the block and cylinders getting cleaned up.
Thanks guys.
