Considering a Fibreglass front shell (Flip Front) https://www.ausmini.com/forums/viewtopic.php?f=2&t=82100 |
Author: | Jay95 [ Mon Jul 15, 2013 7:10 am ] |
Post subject: | Considering a Fibreglass front shell (Flip Front) |
I have looked at the possibility of removing the current panels on my 77 Layland Mini and replacing with a fibreglass flip front, has anyone done this in Brisbane? I have seen this shell that is available at Minisports; http://www.minisport.com.au/category25_7.htm Although this is for the round nose I am hoping I can get them for a 77 Leyland, if you have done it what are the pros and cons for this mod and is there anyone in Brisbane who makes the them or at least closer than Adelaide. Thanks |
Author: | TheMiniMan [ Mon Jul 15, 2013 8:39 am ] |
i can helpo with a fibreglass clubman front nose |
Author: | Kennomini [ Mon Jul 15, 2013 6:41 pm ] |
I think their may be an issue with QLD rego/legalities ![]() |
Author: | Timbo [ Mon Jul 15, 2013 9:55 pm ] |
Assuming they are legal, I'd be worried about safety. In a head-on you're not going to get any crumple zone at all, instead its going to slide up the diagonally cut A panels and have a go at cutting your head off. Tim |
Author: | Kennomini [ Mon Jul 15, 2013 10:02 pm ] |
Timbo wrote: Assuming they are legal, I'd be worried about safety. In a head-on you're not going to get any crumple zone at all, instead its going to slide up the diagonally cut A panels and have a go at cutting your head off.
Tim I think a fiber glass panel will flex out of the way over the windscreen. But crash safty is the main reason it may be ilegial, more so if a pedstirian gets cut or scrached if they jump out in front of you where as with steel panels they'll just cop a solid hit and bounce out of the way ![]() Check with QLD transport and or an engineer before you make any plans just to be sure. |
Author: | 16sth [ Tue Jul 16, 2013 7:38 pm ] |
Kennomini wrote: I think a fiber glass panel will flex out of the way over the windscreen. But crash safty is the main reason it may be ilegial, more so if a pedstirian gets cut or scrached if they jump out in front of you where as with steel panels they'll just cop a solid hit and bounce out of the way
![]() Check with QLD transport and or an engineer before you make any plans just to be sure. When I showed an engineer up here photos of potential 'upgrades' he asked if I was thinking of a flip front. I said I thought glass fibre was illegal due to the shattering. He said there were different grades(?) of glass fibre. Some shatter, some flex. He also said he had neither read nor been told about flip fronts not being able to be certified and he certs the new NCOP regs. (Having said that if I was having a flip front I would make it from steel panels.) |
