thrust bearing removal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82227
Author:  IndigoBlueCooperS [ Sat Jul 27, 2013 9:46 pm ]
Post subject:  thrust bearing removal
Is there a sound way to remove a good thrust bearing from a worn plunger shaft?
The bearing is one of the originals, and the shaft is worn where the ball fits in.
Author:  Mick [ Sat Jul 27, 2013 10:08 pm ]
You would need to support the inner race as you press the plunger through. That would mean a lot of trouble as you would need to cut away the oversize outer end of the plunger and machine a hollow dolly to allow the plunger to be pressed through. Still not a guarantee however.
Author:  drmini in aust [ Sat Jul 27, 2013 10:39 pm ]
If all else fails you could probably press it off, don't use a BFH and punch for this, the impacts will bugger the balls/rollers and track.
Author:  simon k [ Mon Jul 29, 2013 9:44 am ]
I tried pressing one off once, f*cked it royally.... no way to get to the inner race on the outer side of it
I'll have some of the good bearings to pass on this week though!
