It is currently Sun Aug 10, 2025 2:13 am
 Post subject: Clubman ignition switch
PostPosted: Wed Jul 31, 2013 9:45 am
Is there any way of pulling these apart to fit a key to them like u can a round nose door lock
PostPosted: Thu Aug 01, 2013 5:34 pm
I think nobody has replied because we don't know what you're talking about...
Are you referring to a push button start?
PostPosted: Thu Aug 01, 2013 6:48 pm
I think he means he has a clubman ignition switch, the type on the steering column and he wants to know if you can change the barrel to suit a different key?
If so i would assume yes but wouldn't really know
PostPosted: Thu Aug 01, 2013 6:54 pm
Yes the one that goes on the Column don't worry I figured out how to pull it apart and change the wafers to fit a key :)
PostPosted: Thu Aug 01, 2013 7:08 pm
There was a discussion about this from back in February. Clubman Van's had the ignition on the column right??
Anyway, I'll add it in here for information.
http://www.ausmini.com/forums/viewtopic ... f0529b7e37
Users browsing this forum: No registered users and 118 guests
