It is currently Wed Jul 30, 2025 7:19 pm
 Post subject: A few Questions on resto
PostPosted: Sun Jun 19, 2005 11:05 am
I have began on my delux stripping it all and sanding rust etc
i have only ever had later model minis and behind the lights etc the wires just cliped apart but on this early model mini every wire is connected unable to come apart do i have to cut them or it there a way.
I am going to put a new wiring loom in for sure anyways
2. i have taken windscreen and rear screen out doors are off but the back windows are still in is there an easy way to get them off
thanks for any info
PostPosted: Sun Jun 19, 2005 12:17 pm
thanks for any info
Marc...they are easy to remove...first undo the two screws holding the chrome over centre latches to the body, inside the car, near the rear window.
then underneath the window rubber at the front are a 8 or so small screws holding the front hinge of the window.....when you start removinging these screws you need to hold the weight of the window.
PostPosted: Sun Jun 19, 2005 5:51 pm
For the wires behind the lights you can cut them and buy plugs which connect the wires back together.
PostPosted: Mon Jun 20, 2005 11:57 am
Such cutting can be performed with scissors cutters or other cutting implements. :lol:
Sorry I'm just being a wally now.
PostPosted: Mon Jun 20, 2005 12:20 pm
mike yeah your right mate
i know pretty simple questions but just wondered if cutting and then soldering or connecting them back together was the only way.
but as i said im up for a new harness anyway so it doesnt matter i quess
PostPosted: Mon Jun 20, 2005 12:25 pm
Those wires on a Deluxe should just clip on/off, unless someone has soldered them! :shock:
If that's what it has I'd redo them with spade terminals. :wink:
PostPosted: Mon Jun 20, 2005 12:52 pm
as far as the wiring harness goes is there any reason that i cant put a late model harness in and use this (this is my plan) then recconect it all.
PostPosted: Mon Jun 20, 2005 1:17 pm
For the wiring harness check out a clasic car wiring place in coffs harbour....can't remember the name. They do the mini harness to original specs inc colours and a numbered diagram for around 300 bux. Takes around 3 days to post
PostPosted: Mon Jun 20, 2005 11:34 pm
http://www.vinwire.com.au/
Vintage Wiring Harness
P.O. Box 520, Bellingen NSW 2454, Australia
E-mail: [email protected] Fax: +61 2 6655 9519
67' Matic
73' S
PostPosted: Tue Jun 21, 2005 5:51 am
I could never understand why people insist on having a separable connection there instead of a solid link. The area is exposed to so much crap while driving - most connectors will deteriorate over time. And how often does anyone have to separate those wires? I mean in the extreme cases where youre removing the whole harness, you can just as well cut them and resolder + heat shrink later,
But for an easy connection - Narva and Hella both do multi spade connectors which are ok (well Hella is, Narva's ones are addequate at best). Or get those boating solder + shrink connection the Doc has been mentioning forever (but still hasn't fitted afaik :) ).
 Post subject: long wires
PostPosted: Wed Jun 22, 2005 1:01 pm
bump...
PostPosted: Wed Jun 22, 2005 1:02 pm
the existing wires are all one piece AFAIR and terminate in breakable connections inside the engine compartment just under the grill bar....
