Slave cylinder line
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82303
Author:  AWOODY [ Fri Aug 02, 2013 8:04 pm ]
Post subject:  Slave cylinder line
Has anybody run a direct flexible line from the master cylinder to the slave instead of the 2 piece system that is standard .
Author:  TheMiniMan [ Fri Aug 02, 2013 8:06 pm ]
yes
Author:  boomini [ Fri Aug 02, 2013 8:21 pm ]
yes mine has a flexible line direct from the master to slave cylinder.. works fine...
Author:  AWOODY [ Fri Aug 02, 2013 8:37 pm ]
Any disadvantages? I am using a falcon slave cylinder.
Author:  boomini [ Fri Aug 02, 2013 9:09 pm ]
not that i am aware off, works well for me, any reason your using a ford slave cylinder???
Author:  AWOODY [ Sat Aug 03, 2013 5:11 pm ]
Well I was at a mates place to change the clutch arm etc as I thought that was the problem but it turned out to be the slave cylinder , I had taken a spare everything with me but the slave cylinder was new about 20 yrs ago and so was it was stuck , my mate had a falcon one there as a spare so we fitted that and all was well with the world. Is the flexible hose off something in particular or did you have it made ?
Author:  boomini [ Sat Aug 03, 2013 6:36 pm ]
it came with the last mini i bought so i couldnt tell you, i think minispares sell them for a late rover version?? not too sure tho, it has banjo fittings on bothe ends
Author:  AWOODY [ Sun Aug 04, 2013 9:22 am ]
Ok I will have a look, Thanks
