It is currently Wed Aug 06, 2025 2:30 am
 Post subject: Steering column shroud
PostPosted: Fri Aug 02, 2013 10:43 am
I'm wondering if it's a legal requirement to have a steering shroud to get a RWC. This is the plastic that goes over the steering column and covers the mechanisms for the indicator stick.
Any ideas where to get one affordably? I'm happy not running one but I'm not sure if it'll pass RWC without it
PostPosted: Fri Aug 02, 2013 11:04 am
Generally speaking, the interior of a car to pass roadworthy requirements must not have any sharp protrusions in front of the driver, and larger surfaces should be padded.
A column shroud itself doesn't add much protection, so you should be able to get away with it since its not in a place thats of real danger to the driver.
On the other hand, its also upto the discretion of the roady man - if he doesn't like it then I wouldn't argue with them. Main reason to have it is so you don't have electrical issues with whatever is on the column.
If you really can't get one, just go to the post office, buy a heavy wall cardboard tube and put that there with some gaffer tape! :lol:
PostPosted: Fri Aug 02, 2013 11:17 am
hahah that sounds brilliant! I can put really cheap carbon fibre vinyl over it to make it look even more like a real part.
PostPosted: Fri Aug 02, 2013 11:26 am
Post a pic!
:lol:
PostPosted: Fri Aug 02, 2013 12:49 pm
what year column shroud are you looking for?
i have 2nd hand ones here of both early & late
Matt
0407 135 656
