led lights for cooper s dash
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82514
Author:  brett [ Mon Aug 26, 2013 11:25 pm ]
Post subject:  led lights for cooper s dash
Hi guys. Just wondering if any one sells the led bulbs for the.dash ?
Cheers Brett [/i]
Author:  69k1100 [ Mon Aug 26, 2013 11:45 pm ]
wallie wrote:
just T10 leds off ebay, i had to modify the T10 holder a fraction to fit the base was about 1mm too wide & there was a lip around the top that stopped it from fitting in the back of the cluster, but other than that i just used the stock T10 bulb holders
Author:  brett [ Tue Aug 27, 2013 12:35 am ]
Isn't that clubman bulbs ? These are tiny edison screw
Author:  MINImal effort [ Tue Aug 27, 2013 11:31 pm ]
Try looking for LED E10 bulbs....
I bought a whole stack off eBay direct from China for a pittance and only had 3 duds in lots of bulbs.
(I've heard don't replace your alternator warning light bulb with LED - it needs the resistance of a normal bulb to work properly - but may want to confirm that )
I think I bought something like this in various colours (red, clear etc):
http://www.ebay.com.au/itm/10pcs-White-E10-12V-Led-Tower-Flood-Light-for-LIONEL-WL-ay-/140906654405?pt=AU_B_I_Electrical_Test_Equipment&hash=item20ceb0eac5
Have "bench tested" but not yet finished the car yet....
Author:  wallie [ Tue Aug 27, 2013 11:41 pm ]
yep leyland onwards are T10 wedge & morris is an E10 Edison
ebay is the best place can pick them up for about $1 a bulb
Author:  wallie [ Tue Aug 27, 2013 11:42 pm ]
Author:  slide [ Sat Aug 31, 2013 12:40 pm ]
Post subject:  Re: led lights for cooper s dash
My Smiths gauges have bulbs with bayonet type fittings, not screw in. Are there any swap in LEDs available for these?
Author:  MINImal effort [ Sat Aug 31, 2013 7:08 pm ]
Yep .... look for BA9S ....
Author:  wallie [ Sun Sep 01, 2013 10:31 am ]
your number plate lights are also ba9s... well in my van they are but could be different in sedans
Author:  Gallinski [ Mon Sep 16, 2013 10:08 am ]
Does any wiring need to be replaced in order to accomodate the new LED globes?
Author:  wallie [ Mon Sep 16, 2013 10:40 am ]
nope, led's use less power than a standard bulb, only thing that need to change (maybe) would be the flasher unit if you put them in your indicators as they may flash faster
Author:  1275LS [ Mon Sep 16, 2013 10:43 pm ]
They wont flash at all as the standard flasher unit doesn't detect the current from the LED's as it is so low.
A suitable Narva flasher is available at about $30 each.
Don't do a load resistor setup as the LED flasher unit setup will allow you to drop the load right off in your wiring but the load resistor wont. And the load resistor is fiddly as you have to get the balance right to get it not to overheat. the ones I saw had resistors with huge wattage capacities to deal with the heat generated if the balance isn't correct.
I am sure Tony B. can correct any errors in the above but broadly speaking I believe it is correct.
Author:  Mick [ Tue Sep 17, 2013 11:52 am ]
You are correct, to simulate the indicators to the flasher can, you would need to simulate the load. 4x5 watt bulbs make for a 20 watt resistor load. Even if it is only on 50 % of the time, a ten watt resistor is quite large requiring a bulky heatsink. it will cost close to 30 bucks anyway, so much smarter to get the low load flasher can.
