It is currently Sun Aug 24, 2025 5:25 pm
PostPosted: Fri Aug 30, 2013 12:34 pm
I am thinking about putting a 1275 into my countryman as I simply do not use it as the 850 is gutless as hell. Fine when you are up to speed but it just takes so long to get there.
I dont want to be chopping holes in the floor to change to rod or remote (fixed this hole when I restored it back to original!) but I do have a gearbox here from a K van. Am I right in thinking I can bolt a 1275 to this gearbox and use the original magic wand/pudding stirrer hole?
Thanks in advance
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Fri Aug 30, 2013 1:08 pm
Can't answer that one, but I have seen some gear linkage kits (like say a KAD internal rod one) that use the 850 gearstick hole instead of needing a new one cut.
PostPosted: Fri Aug 30, 2013 2:45 pm
yep, as long as its a 22G1128 case it'll bolt right up
22G1128 should be cast into the front of the case on the passenger side above the ribs
PostPosted: Fri Aug 30, 2013 4:27 pm
It was a bit like checking if I had the winning raffle ticket..BINGO im a winner!
Now I dont know if its good news or bad, my tin was just starting to build up. If I embark on this project it will be hello Mr empty pockets again :P
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
Users browsing this forum: No registered users and 212 guests
