1275 into 850 gearbox question. https://www.ausmini.com/forums/viewtopic.php?f=2&t=82539 |
Author: | Babes [ Fri Aug 30, 2013 12:34 pm ] |
Post subject: | 1275 into 850 gearbox question. |
I am thinking about putting a 1275 into my countryman as I simply do not use it as the 850 is gutless as hell. Fine when you are up to speed but it just takes so long to get there. I dont want to be chopping holes in the floor to change to rod or remote (fixed this hole when I restored it back to original!) but I do have a gearbox here from a K van. Am I right in thinking I can bolt a 1275 to this gearbox and use the original magic wand/pudding stirrer hole? Thanks in advance |
Author: | Harley [ Fri Aug 30, 2013 1:08 pm ] |
Post subject: | Re: 1275 into 850 gearbox question. |
Can't answer that one, but I have seen some gear linkage kits (like say a KAD internal rod one) that use the 850 gearstick hole instead of needing a new one cut. |
Author: | simon k [ Fri Aug 30, 2013 2:45 pm ] |
Babes wrote: I dont want to be chopping holes in the floor to change to rod or remote (fixed this hole when I restored it back to original!) but I do have a gearbox here from a K van. Am I right in thinking I can bolt a 1275 to this gearbox and use the original magic wand/pudding stirrer hole? yep, as long as its a 22G1128 case it'll bolt right up 22G1128 should be cast into the front of the case on the passenger side above the ribs |
Author: | Babes [ Fri Aug 30, 2013 4:27 pm ] |
It was a bit like checking if I had the winning raffle ticket..BINGO im a winner! Now I dont know if its good news or bad, my tin was just starting to build up. If I embark on this project it will be hello Mr empty pockets again ![]() |
