Carbies to distributor pipe position? https://www.ausmini.com/forums/viewtopic.php?f=2&t=82580 |
Author: | haze blue 850 [ Sun Sep 01, 2013 8:32 pm ] |
Post subject: | Carbies to distributor pipe position? |
Greetings all. The original Carbies have a little bulb and metal capillary tube which went to the distributor vacuum advance thingo. As it was bent all over the place, I can't work out it's proper "Path". It has a saddle clip which (by size) must sit under the water tap nut. Can anyone post a side on picture of how this is positioned please? Also, can these be bought new anywhere? I like the original look. Cheers Alex |
Author: | captainwaldopepper [ Thu Sep 12, 2013 1:47 pm ] |
Post subject: | Re: Carbies to distributor pipe position? |
Hi Alex If it's the one I'm thinking of, it goes from the carby to the distributore and the saddle clip is bolted onto the thermostat cover. I don't have a photo of the position of the pipe but here's a link to where you can buy one. http://www.ebay.com.au/itm/Advance-Reta ... 821wt_1161 Cheers Dave |
Author: | drmini in aust [ Thu Sep 12, 2013 2:18 pm ] |
I agree with waldo, that's where my 850 had it. |
Author: | haze blue 850 [ Thu Sep 12, 2013 10:38 pm ] |
Thanks Dave & Doc. The links the one I need. This one is too bent to recover. I can go plastic, but the metal does look better. Cheers Alex. |
