Crank Movement Update 23-6-05 https://www.ausmini.com/forums/viewtopic.php?f=2&t=8265 |
Author: | 1380 yellow devil [ Mon Jun 20, 2005 2:07 pm ] |
Post subject: | Crank Movement Update 23-6-05 |
Crank Movement??? How much end float for a crank in a 1275. I have been thinking that I had a clutch problem as every time i Pushed in my clutch I had a scraping noise like as if the clutch was disengaged properly. When I was look at it on the weekend Dad was there and he said that it soulded like it was from the other end that was rubbing. On further inspection we found that the crank was moving to the front of the engine and then rubbing on the radiator shroud and cause the rubbing noise. I have not measuer the amount of movement or the gap between the harmonic balancer and the radiator shroud. |
Author: | 1380 yellow devil [ Mon Jun 20, 2005 8:53 pm ] |
anyone with any info would be great |
Author: | drmini in aust [ Mon Jun 20, 2005 9:03 pm ] |
Standard endfloat on a 1275 is about .003". Any more than .010-.012" I'd pull the motor... if you let it get real loose, the thrust washers can fall out... ![]() ![]() |
Author: | 1380 yellow devil [ Mon Jun 20, 2005 9:28 pm ] |
Thanks I will check for that. It has only done 35 000km since rebuild and it very rearly goes past 5000 rpm |
Author: | TheMiniMan [ Mon Jun 20, 2005 10:06 pm ] |
if the crank thrust washers have been put in the wrong way round, then they don`t last very long at all & the crank will happilly grind away your main cap & block ,,,YUKKY!!!!!!!!!! I`d pull it out if it`s travelling that far |
Author: | 1380 yellow devil [ Mon Jun 20, 2005 10:19 pm ] |
I has been doing it fot eh last 6 - 8 months and is slowly getting worse I think a engine removal will be in store ![]() ![]() |
Author: | 1380 yellow devil [ Thu Jun 23, 2005 8:04 am ] |
I have measure roughly the gape between the Rad shroud and the flywheel and 0.025" feeler gauge will slide nicely through so I think a engine removal will be in place. I will have to set up a dail gauge to check it properly first. |
Author: | minicranks [ Thu Jun 23, 2005 8:19 am ] |
as matt says you might have 1 of the thrusts in the wrong way and it has caused it to wear out either the crank or centre main cap. I hope its not too bad but i would definatly pull the motor out and have a strip down. I have had end float problems before and all of them have been terminal within 100km so i hope its not too bad for you. |
Author: | J_A_M [ Thu Jun 23, 2005 10:12 am ] |
oooohhh...nasty stuff ![]() At least you figured it out now.....! |
