Wheel Cylinder Problem https://www.ausmini.com/forums/viewtopic.php?f=2&t=82662 |
Author: | mini_mad_matt [ Sat Sep 07, 2013 5:26 pm ] |
Post subject: | Re: Wheel Cylinder Problem |
Yea just rip in with a file, fairly common problem |
Author: | jubblies [ Sat Sep 07, 2013 5:32 pm ] |
Post subject: | Wheel Cylinder Problem |
I read somewhere it needs to be filed out, unsure where I read it? I think it was when upgrading from 15/16ths to 1 inch. Are these the 1" cylinders? For memory mine did fit and I was surprised I didn't need to do any mods! I recently upgraded the fronts to discs and the rear cylinders to 5/8ths and was surprised when they fit without mods as well. Justin |
Author: | MiniBill [ Sat Sep 07, 2013 6:47 pm ] |
Thanks mmm & Jubblies , they are 15/16 they were the ones karcraft recomended for my model part #GWC126 & 127 " 73 clubby " so i will just file them out then , bit of a pain but what can you do " hopefully the rear ones fit without any mods". Cheers Bill |
Author: | drjbeam [ Sat Sep 07, 2013 10:01 pm ] |
You can get the back plates from karcraft for the 15/16 wheel cyl i changed mine cause one adjuster was loose and kept slipping There is post on here about the holes a few weeks ago viewtopic.php?f=2&t=82438 Another one of your threads bill page 2 read what karcraft wrote Mg spares at smithfield sell 1' wheel cylinders thats where i got mine from before i realised the adjuster was stuffed on passenger side |
Author: | MiniBill [ Sun Sep 08, 2013 10:36 am ] |
drjbeam wrote: You can get the back plates from karcraft for the 15/16 wheel cyl i changed mine cause one adjuster was loose and kept slipping There is post on here about the holes a few weeks ago viewtopic.php?f=2&t=82438 Another one of your threads bill page 2 read what karcraft wrote Mg spares at smithfield sell 1' wheel cylinders thats where i got mine from before i realised the adjuster was stuffed on passenger side Thats rather disapointing then as Karcraft were the ones telling me which wheel cylinders i needed for my 73 mini and reading that post he says from 74 onwards they were 15/16 ..... damn not sure what to do now as the back plates are over $100 each and dont need replacing anyway ..... arrrggghhh . Edit : I will ring Karcraft tomorrow and organise an exchange. |
Author: | Karcraft [ Sun Sep 08, 2013 11:57 am ] |
Our previous post. There is nothing wrong with the wheel cylinders. In about 1974 Leyland changed the stud pattern and backing plates when they introduced 15/16" wheel cylinders to replace the 1" wheel cylinders. To stop people replacing a 1" cylinder with a 15/16" cylinder Leyland changed the stud pattern slightly. This was a safety measure. People are too quick to always blame the replacement part. ++++++++++++++++++++++++ If fitting the latter 15/16" cylinders to a 1" car all you have to do is slightly elongate the hole in the backing plate. Using a round file it will take about 1 minute to do. This slight modification has been around for over 30 years so it is not new ! Hope this helps. |
Author: | MiniBill [ Sun Sep 08, 2013 12:46 pm ] |
Karcraft wrote: Our previous post. There is nothing wrong with the wheel cylinders. In about 1974 Leyland changed the stud pattern and backing plates when they introduced 15/16" wheel cylinders to replace the 1" wheel cylinders. To stop people replacing a 1" cylinder with a 15/16" cylinder Leyland changed the stud pattern slightly. This was a safety measure. People are too quick to always blame the replacement part. ++++++++++++++++++++++++ If fitting the latter 15/16" cylinders to a 1" car all you have to do is slightly elongate the hole in the backing plate. Using a round file it will take about 1 minute to do. This slight modification has been around for over 30 years so it is not new ! Hope this helps. Thanks for the reply , i will do the mod then Thanks again for not only the help with the parts i needed but also with the fast shipping and the after sales help on these forums , its greatly appreciated.My next order for my windscreen seals etc will be in soon. Cheers Bill |
Author: | michaelb [ Sun Sep 08, 2013 6:26 pm ] |
I have now done this mod to all my drum brake minis. I usually use a dremel, much quicker than a file ![]() The rears have never been a problem, only the front. |
Author: | drjbeam [ Sun Sep 08, 2013 6:47 pm ] |
I was the other way round fitting 1' cyl to 15/16 backplates so i just went back and got some 15/16 cyl cause every thing was coming out to do the oil seals and inner cvs at the time |
Author: | MiniBill [ Wed Sep 11, 2013 9:17 pm ] |
Post subject: | Re: Wheel Cylinder Problem FIXED |
Modded the backplate and the cylinders fit fine " had a harder time putting the spings and shoes in ![]() Thanks all Cheers Bill |
