refurbished my contessas https://www.ausmini.com/forums/viewtopic.php?f=2&t=82694 |
Author: | Blunder [ Mon Sep 09, 2013 10:53 pm ] |
Post subject: | refurbished my contessas |
Hi all, I have a couple of sets of the shallow offset contessas sitting in wait and decided to spruce a set up..... From this ![]() Then had the centres soda blasted, to get back to a clean surface and then hand painted on a 2 pak expoxy black, I did mask the outer rim for blasting and painting but you can get it perfect! Then took then to the professionals for a polish down to 3000 grit, the also too the rim lip back to a good finish and highlighted the step from silver rim to black. Guy at polish could believe how strong the paint was, he thought they were powder coated! ![]() Hope you like |
Author: | Kennomini [ Tue Sep 10, 2013 6:26 pm ] |
Post subject: | Re: refurbished my contessas |
They look awesome, what'd the pro's charge you to polish them? (only two wheels correct?). |
Author: | Blunder [ Tue Sep 10, 2013 9:28 pm ] |
Perth wheel repairs in East cannington polished them up at $30 bucks a rim and there were 4! It's not a cheap thing but it takes a lot of elbow grease to get them that shiny and by the time you buy all the bits etc you would probably spend just as much.... |
Author: | MiniKit [ Wed Sep 11, 2013 7:36 pm ] |
Makes mine look craptastic. ![]() Sent from my RM-892_apac_australia_new_zealand_259 using Tapatalk |
Author: | MiniBill [ Wed Sep 11, 2013 9:27 pm ] |
What a huge difference in the before and after photo's ....... they turned out great |
Author: | drmini in aust [ Thu Sep 12, 2013 2:40 pm ] |
Looks good. ![]() I sprayed mine with VHT quickcoat gloss black acrylic spray cans, then hand polished them with Mothers mag wheel polish. http://www.flickr.com/photos/31275265@N05/9449115260/ |
Author: | Haydn [ Thu Sep 12, 2013 3:35 pm ] |
Hey Doc, Did you sandblast them before you sprayed them black? |
Author: | drmini in aust [ Thu Sep 12, 2013 4:02 pm ] |
Nope, I paint stripped them with Bunnings `Digger' stripper.. Then I machined off any gutter rash from the outer rim edge and wet sanded them in the lathe at work. With 240>600>1200 paper. Then I masked the rims up, sprayed the centres with etch prime, then 6 coats of black, finally I hand polished the outer rim with Mothers polish. Didn't take me long, all it cost was 1L of stripper, 1 spray can of epoxy etch primer, 2 cans VHT `quickcoat' gloss black, and some wet & dry paper. ![]() [edit] The Contessa nuts shown are custom S/S ones, from TheMiniMan. I doubt he has any left, but you could ask him nice.. |
Author: | Haydn [ Thu Sep 12, 2013 4:18 pm ] |
You're a champ Doc. I've been scratching my head as I got quotes to sandblast, paint n polish and got little change out of $150 each!! So now.....Paint Stripper, Etch Primer, Black gloss n a bit of elbow grease. I'm on to it! Cheers again. Haydn |
Author: | Lillee [ Thu Sep 12, 2013 4:42 pm ] |
Haydn wrote: You're a champ Doc. I've been scratching my head as I got quotes to sandblast, paint n polish and got little change out of $150 each!! So now.....Paint Stripper, Etch Primer, Black gloss n a bit of elbow grease. I'm on to it! Cheers again. Haydn I used this method and it came up great. Just remember to wash the paint stripper off thoroughly. Wash it again after that. I also painted mine over the top with clear coat gloss |
Author: | drmini in aust [ Thu Sep 12, 2013 4:49 pm ] |
One of the wheels I did (unused, NOS) had clear all over it, it had gone patchy and yellowed. After the trouble I had stripping it off, No way would I put clear over them... I just give the outer rims a quick polish with Mothers mag polish every 6 months or so. The other set I did 3 years ago still look like new. |
Author: | Haydn [ Mon Sep 16, 2013 4:14 pm ] |
Cheers Boys, Bought the paint stipper today. I'll attempt to do a few before and after pics. Haydn |
