It is currently Sun Aug 24, 2025 5:18 pm
PostPosted: Tue Sep 10, 2013 6:36 pm
I just noticed this the other day.Image
I thought id get a nice new braded line one when I ordered some parts from mini spares a while ago.
Keep in mind that even though its been on there for about a year. The clutch has probably only been pressed a dozen times over that year due to the car sitting in my garage going nowhere.
Pretty terrible I thought :evil:
Time to put the old rubber one back on I think
Has anyone else had this happen before??
Dusk Blue
1964 850
PostPosted: Tue Sep 10, 2013 7:14 pm
I'm only guessing, but from the phot it looks like the hose has been installed with a slight kink in it. This intern will damage the internal pipe.
Braided lines don't like to be twisted!
Cheers Shane
PostPosted: Tue Sep 10, 2013 7:24 pm
I prefer non-braided lines, you can see what condition the rubber is in. And often they are better made. I have seen several instances of braided lines having weak crappy rubber in them, because they rely on the braid to stop the hose from blowing out.
Examples I have seen/used:
UK made braided industrial compressed air hoses.
UK made bling oil cooler hoses for Minis.
In both these cases you can watch the hose squirm (get bigger & shorter) when the pressure hits it.
And as seen in the clutch hose pic above they do NOT like being twisted.
PostPosted: Tue Sep 10, 2013 7:42 pm
Agreed. Incorrect fitting by the look of it.
Kink = a build up of presssure in the hose = failure.
I have fitted many Goodridge braided hoses all have been fine.
PostPosted: Tue Sep 10, 2013 9:00 pm
Looks kinked in the photo but it is actually the outer plastic coating bloated out with brake fluid. Bad hose
PostPosted: Wed Sep 11, 2013 6:16 am
Yea, it definitely isn't/wasn't kinked. it is a bit of a funny camera angle.
Above the yellow bit is a bubble in the outer coating.
Dusk Blue
1964 850
PostPosted: Wed Sep 11, 2013 9:35 am
Wow, quality hose :roll:
Lillee - 1969 Morris Mini K
Users browsing this forum: Bing [Bot] and 218 guests
