What's the general consensus with hub installation https://www.ausmini.com/forums/viewtopic.php?f=2&t=82707 |
Author: | MiniKit [ Wed Sep 11, 2013 7:49 pm ] |
Post subject: | What's the general consensus with hub installation |
About to put the front of the car back together. Is it better to put the hub back on and then slide the drive flange in or fit the flange and slide the drive shaft into it as you fit it all back onto the top and bottom suspension arms? Sent from my phone cause I can. |
Author: | Kennomini [ Wed Sep 11, 2013 8:02 pm ] |
Post subject: | Re: What's the general consensus with hub installation |
Either way I think, I assembled mine off the car then bolted onto the suspension arms but my engine was not in the car either. |
Author: | TheMiniMan [ Thu Sep 12, 2013 7:34 am ] |
MiniKit wrote: About to put the front of the car back together. Is it better to put the hub back on and then slide the drive flange in or fit the flange and slide the drive shaft into it as you fit it all back onto the top and bottom suspension arms? Sent from my phone cause I can. i build the complete hub-assy up & fit it as a complete unit |
