Annoying carby issue... https://www.ausmini.com/forums/viewtopic.php?f=2&t=82718 |
Author: | mattsmadmini [ Thu Sep 12, 2013 4:50 pm ] |
Post subject: | Annoying carby issue... |
So i put a HS6 on my motor recently, im having an annoying time with it to be honest, ive tuned it and got a nice rich needle in it etc... but i having trouble with maybe the shaft? let me explain start engine: idle fine rev engine: make smiley face Stop revving engine in an attempt to idle: crappy very high idle, i have to twist the shaft to make him settle idle screw is fine (when the return/stop gets to it) but it wont automatically go all the way back to that spot... thoughts? |
Author: | drmini in aust [ Thu Sep 12, 2013 4:53 pm ] |
Post subject: | Re: Annoying carby issue... |
Sounds like the butterfly plate is not centred. Take carb off, undo idle stop screw to clear stop, loosen both butterfly screws 1/4 turn. Hold throttle closed and do the 2 screws back up. Hold up to light, should be none? visible. Stake the screws gently again if needed. Refit carb, adjust idle stop screw. |
Author: | Bubbacluby [ Thu Sep 12, 2013 4:56 pm ] |
I know I'm stating the obvious but.... Have you got a strong enough spring on it to pull the butterfly fully closed once you release the throttle? |
Author: | mattsmadmini [ Thu Sep 12, 2013 4:58 pm ] |
yeh forgot to mention that, 2 v. strong springs |
Author: | IndigoBlueCooperS [ Thu Sep 12, 2013 8:42 pm ] |
Do you have a little bit of free play in the cable. If not it can hold it open a bit. |
Author: | 1310/71 [ Sat Sep 14, 2013 6:16 am ] |
Do you have a weber? - swap it for that ![]() |
Author: | drmini in aust [ Sat Sep 14, 2013 8:31 am ] |
1310/71 wrote: Do you have a weber? - swap it for that ![]() Bwahaha.. good call KB. It wasn't broke before was it... but ya fixed it by fitting an SU. ![]() |
