It is currently Sun Aug 17, 2025 5:52 pm
 Post subject: Annoying carby issue...
PostPosted: Thu Sep 12, 2013 4:50 pm
Milatsmadmini
So i put a HS6 on my motor recently, im having an annoying time with it to be honest, ive tuned it and got a nice rich needle in it etc... but i having trouble with maybe the shaft? let me explain
start engine: idle fine
rev engine: make smiley face
Stop revving engine in an attempt to idle: crappy very high idle, i have to twist the shaft to make him settle
idle screw is fine (when the return/stop gets to it) but it wont automatically go all the way back to that spot...
thoughts?
PostPosted: Thu Sep 12, 2013 4:53 pm
Online
Sounds like the butterfly plate is not centred.
Take carb off, undo idle stop screw to clear stop, loosen both butterfly screws 1/4 turn.
Hold throttle closed and do the 2 screws back up. Hold up to light, should be none? visible. Stake the screws gently again if needed.
Refit carb, adjust idle stop screw.
PostPosted: Thu Sep 12, 2013 4:56 pm
I know I'm stating the obvious but....
Have you got a strong enough spring on it to pull the butterfly fully closed once you release the throttle?
PostPosted: Thu Sep 12, 2013 4:58 pm
Milatsmadmini
yeh forgot to mention that, 2 v. strong springs
PostPosted: Thu Sep 12, 2013 8:42 pm
Do you have a little bit of free play in the cable. If not it can hold it open a bit.
PostPosted: Sat Sep 14, 2013 6:16 am
Do you have a weber? - swap it for that :lol:
PostPosted: Sat Sep 14, 2013 8:31 am
Online
Bwahaha.. good call KB. It wasn't broke before was it... but ya fixed it by fitting an SU. 8)
Users browsing this forum: drmini in aust and 343 guests
