It is currently Thu Aug 14, 2025 1:22 am
 Post subject: Facet ?? Fuel pump
PostPosted: Sat Sep 14, 2013 7:00 pm
Hey guys will a facet fuel pump pump to much pressure for a std carbie set up ??
 Post subject: Re: Facet ?? Fuel pump
PostPosted: Sat Sep 14, 2013 7:19 pm
Plenty of facet fuel pumps being used, you need to read the spec sheet and make sure the fuel pressure is around 3 PSI.
I use the Facet electronic one, it feeds my 1360 with 45 Dellorto just fine..
It worked fine with my HS6 SU on the 1412 as well.
http://www.ebay.com.au/itm/Fuel-Pumps-F ... 53f3a5ba96
PostPosted: Sun Sep 15, 2013 10:12 am
and in-line regulators are cheap :arrow:
PostPosted: Sun Sep 15, 2013 11:20 am
No need for a regulator if you buy the right Facet pump. :D
Mine is a 40104N.
If you happen to buy a Purolator regulator, get a pressure gauge too because their calibrations are hopelessly out.
Users browsing this forum: No registered users and 288 guests
