Facet ?? Fuel pump https://www.ausmini.com/forums/viewtopic.php?f=2&t=82738 |
Author: | i got a mini [ Sat Sep 14, 2013 7:00 pm ] |
Post subject: | Facet ?? Fuel pump |
Hey guys will a facet fuel pump pump to much pressure for a std carbie set up ?? |
Author: | Mick [ Sat Sep 14, 2013 7:19 pm ] |
Post subject: | Re: Facet ?? Fuel pump |
Plenty of facet fuel pumps being used, you need to read the spec sheet and make sure the fuel pressure is around 3 PSI. drmini in aust wrote: I use the Facet electronic one, it feeds my 1360 with 45 Dellorto just fine..
It worked fine with my HS6 SU on the 1412 as well. http://www.ebay.com.au/itm/Fuel-Pumps-F ... 53f3a5ba96 |
Author: | 9YaTaH [ Sun Sep 15, 2013 10:12 am ] |
and in-line regulators are cheap ![]() |
Author: | drmini in aust [ Sun Sep 15, 2013 11:20 am ] |
No need for a regulator if you buy the right Facet pump. ![]() Mine is a 40104N. If you happen to buy a Purolator regulator, get a pressure gauge too because their calibrations are hopelessly out. |
