temp guage https://www.ausmini.com/forums/viewtopic.php?f=2&t=82792 |
Author: | carter [ Wed Sep 18, 2013 7:45 pm ] |
Post subject: | temp guage |
i have several smiths temp guages. i have tried two of them and they both read the same thing, they have 2 wires coming off the back one goes directly to the sender in the head the other to the regulator on the back of the speedo which cuts the volts down.....the problem i have is the guages both of them only go up to 1 quarter of the way, sometimes a lil more but not much but if i earth the wire that goes to the sender it sends the needle moving up to hot. i have been driving this motor it was a brand new rebuilt motor i fear now i may have wrecked it as i was going off the temp guage which was way inaccurate. i boiled the motor and blew a head gasket have replaced both radiator and head gasket but the temp guage still resads the same. |
Author: | brett [ Wed Sep 18, 2013 10:57 pm ] |
Post subject: | Re: temp guage |
Its your temp sender mate. you have to mate them up. there is a tread on here regarding what sender goes with each. Mine sits on 1/4 but mine runs a 5 speed box, and a minispares 2core. and after the run with the mini club a few months back, I put my infra red on it and it said 67deg C. So have a search, and find which coloured one will suit your gauge ![]() |
Author: | carter [ Thu Sep 19, 2013 11:46 am ] |
ok thanks a lot for your reply brett. i have tried more then one sender aswell. i tried my brothers he has a two clock clubman cluster in his and his sender read the same . i have just a standard mini smiths guage. you dont know what colour sender i need do you? |
Author: | Mick [ Thu Sep 19, 2013 11:52 am ] |
Have you tried another voltage regulator? |
Author: | carter [ Thu Sep 19, 2013 1:00 pm ] |
Yes the one i had on before the one that's on now showed a similar reading. I do however know that this regulator is cutting down the volts because my circuit light is duller when the wires connected to the regulator. I have ordered a new temp sender from karkraft hopefully it will be here tomorrow |
