Moke handbrake switches https://www.ausmini.com/forums/viewtopic.php?f=2&t=82809 |
Author: | _666_ [ Fri Sep 20, 2013 8:44 am ] |
Post subject: | Moke handbrake switches |
Where can I get one of these bad boys ? http://poida97.files.wordpress.com/2010/05/img_2921.jpg |
Author: | drmini in aust [ Fri Sep 20, 2013 9:04 am ] |
Post subject: | Re: Moke handbrake switches |
It looks like a Clubby door switch. NLA now new I think. I fitted Rover ones to my Mini doors, they are well made (in Malta!) and work good. The extra screw and copper strip behind it gives a better earth than originals. http://www.minispares.com/search/classi ... witch.aspx |
Author: | Irish Yobbo [ Fri Sep 20, 2013 9:30 am ] |
They are different to the clubby door switches, but same principle of operation. The clubby door switches are held in with a screw, these have metal clips at the back that hold them in the mounting hole. There's not much to them if you want to have a crack at fixing your old one - but if you need a new one, I've never seen them for sale. |
Author: | drmini in aust [ Fri Sep 20, 2013 9:32 am ] |
Oz Clubby door switches had no screw. They looked just like the one in 666's pic. |
Author: | Irish Yobbo [ Fri Sep 20, 2013 9:36 am ] |
drmini in aust wrote: Oz Clubby door switches had no screw. They looked just like the one in 666's pic. That's interesting! My '78 clubby has the screw version! Perhaps they were 'fixed' at some stage - but they look like they've been there a while. I presumed they were like that from the factory. |
Author: | Goldbrocade_62 [ Sat Sep 21, 2013 8:04 am ] |
Irish Yobbo wrote: drmini in aust wrote: Oz Clubby door switches had no screw. They looked just like the one in 666's pic. That's interesting! My '78 clubby has the screw version! Perhaps they were 'fixed' at some stage - but they look like they've been there a while. I presumed they were like that from the factory. I think they changed to the one with the screw later one I've wrecked a few 77/78's that had that style |
Author: | John Smidt [ Sun Sep 22, 2013 3:37 pm ] |
drmini in aust wrote: Oz Clubby door switches had no screw. They looked just like the one in 666's pic. The Clubman was fitted with the switch held in by a Screw around 1975 onward |
Author: | _666_ [ Sun Sep 22, 2013 3:55 pm ] |
Ok so how can I replace the switch ? |
Author: | drmini in aust [ Sun Sep 22, 2013 3:59 pm ] |
Look for an early Clubby new or s/h one or fit a new late type one somehow, with a screw. It's only a switch.... Can you clean up the one you have or is it buggered? |
Author: | _666_ [ Sun Sep 22, 2013 4:01 pm ] |
The spring is buggered, I'll see what I can find |
Author: | John Smidt [ Tue Sep 24, 2013 8:44 am ] |
_666_ wrote: I am currently out of stock and I will not have stock for next three weeks The part number is 13H2018 and is used on MG'S P76 Triumph Jaguar Etc |
Author: | John Smidt [ Tue Sep 24, 2013 7:34 pm ] |
I have found a couple of good second hand ones if that is any use to You |
