It is currently Mon Jul 21, 2025 2:17 am
 Post subject: Moke handbrake switches
PostPosted: Fri Sep 20, 2013 8:44 am
Die Die Die!!
Where can I get one of these bad boys ?
http://poida97.files.wordpress.com/2010/05/img_2921.jpg
PostPosted: Fri Sep 20, 2013 9:04 am
It looks like a Clubby door switch. NLA now new I think.
I fitted Rover ones to my Mini doors, they are well made (in Malta!) and work good. The extra screw and copper strip behind it gives a better earth than originals.
http://www.minispares.com/search/classi ... witch.aspx
PostPosted: Fri Sep 20, 2013 9:30 am
They are different to the clubby door switches, but same principle of operation. The clubby door switches are held in with a screw, these have metal clips at the back that hold them in the mounting hole. There's not much to them if you want to have a crack at fixing your old one - but if you need a new one, I've never seen them for sale.
PostPosted: Fri Sep 20, 2013 9:32 am
Oz Clubby door switches had no screw. They looked just like the one in 666's pic.
PostPosted: Fri Sep 20, 2013 9:36 am
That's interesting! My '78 clubby has the screw version! Perhaps they were 'fixed' at some stage - but they look like they've been there a while. I presumed they were like that from the factory.
PostPosted: Sat Sep 21, 2013 8:04 am
I think they changed to the one with the screw later one I've wrecked a few 77/78's that had that style
PostPosted: Sun Sep 22, 2013 3:37 pm
The Mini King
The Clubman was fitted with the switch held in by a Screw around 1975 onward
PostPosted: Sun Sep 22, 2013 3:55 pm
Die Die Die!!
Ok so how can I replace the switch ?
PostPosted: Sun Sep 22, 2013 3:59 pm
Look for an early Clubby new or s/h one or fit a new late type one somehow, with a screw.
It's only a switch....
Can you clean up the one you have or is it buggered?
PostPosted: Sun Sep 22, 2013 4:01 pm
Die Die Die!!
The spring is buggered, I'll see what I can find
PostPosted: Tue Sep 24, 2013 8:44 am
The Mini King
I am currently out of stock and I will not have stock for next three weeks
The part number is 13H2018
and is used on MG'S P76 Triumph Jaguar Etc
PostPosted: Tue Sep 24, 2013 7:34 pm
The Mini King
I have found a couple of good second hand ones if that is any use to You
Users browsing this forum: Bing [Bot] and 107 guests
