It is currently Wed Jul 23, 2025 6:18 pm
PostPosted: Mon Sep 23, 2013 10:15 am
So i need to replace the wheel cylinders in the front left drum of my clubby (1975)
does anyone know if I need 1" bore or 15/16" bore cylinders? would it marked somewhere on the cylinder to check?
Whats the difference anyway?
Thanks
1975 Hairy Lime/White Clubby
PostPosted: Mon Sep 23, 2013 10:21 am
Measure the diameter of one of the pistons. Buy 4 of the same size you have now.
If you change size, you will need to file the mounting holes in the backplate to fit as they are slightly different. But it's not a big deal if you have to.
Refer recent thread here on the same subject.
PostPosted: Mon Sep 23, 2013 10:33 am
Thanks Doc,
I should have searched initially, just being slack i guess.
I sounds like leyland changed from 1" to 15/16" in around 1974.
so i guess i'll probably need the 15/16" size
PostPosted: Mon Sep 23, 2013 11:50 am
Karcraft sells both sizes I think. I'd measure yours to be sure...
PostPosted: Mon Sep 23, 2013 12:28 pm
Yeah that was my thread i think Doc and i had to file my back plates " very easy to do " , .
Thorlek as doc mentioned Karcraft have both sizes just ring and ask them which ones you need they will know. Very fast delivery and great prices.
Cheers Bill
PostPosted: Mon Sep 23, 2013 12:31 pm
Karcraft only sell 15/16 1" are sold at mg spares smithfield they have a online store since your from melbourne. http://www.mgspareparts.com.au/
My 9/74 had 1" cylinders
