Engine coming out. What to do? https://www.ausmini.com/forums/viewtopic.php?f=2&t=82861 |
Author: | Flash [ Mon Sep 23, 2013 11:13 pm ] |
Post subject: | Engine coming out. What to do? |
As the title says; the engine is coming out tomorrow as it's leaking oil from both ends. Badly. While I have it out, the correct speedo drive will be installed and I'll probably have a look at the slack gearstick linkages. I would also like to fix up the rear breather to the carbs but the one I have is dead. The original will have a hose attached and vented to the ground a la 1962. Is there anything else that I should be doing while the lump is out? It's too good an opportunity to waste. Thanks |
Author: | simon k [ Tue Sep 24, 2013 7:27 pm ] |
Post subject: | Re: Engine coming out. What to do? |
how's the steering rack? much easier with the motor out |
Author: | peterb [ Tue Sep 24, 2013 9:49 pm ] |
bypass hose ![]() |
Author: | blue_deluxe [ Tue Sep 24, 2013 9:57 pm ] |
Coming out the top or bottom? If its coming out the bottom then get the top towers of the subframe welded up. |
Author: | MINImal effort [ Tue Sep 24, 2013 10:01 pm ] |
How was the clutch ? (and if having to fix main seal oil leak - my be worth replacing anyhow while it's all apart...) |
Author: | Flash [ Tue Sep 24, 2013 11:12 pm ] |
Well, that little lot should keep me busy over the long weekend. Thanks all. |
