Gearbox ratios? https://www.ausmini.com/forums/viewtopic.php?f=2&t=82881 |
Author: | Kennomini [ Wed Sep 25, 2013 5:06 pm ] |
Post subject: | Gearbox ratios? |
What would be the gear ratios in a 1990 Rover mini Cooper, rod change box. (I believe the diff ratio is 3.1:1). |
Author: | MINImal effort [ Wed Sep 25, 2013 7:43 pm ] |
Post subject: | Re: Gearbox ratios? |
http://www.goo-net-exchange.com/catalog/ROVER__MINI/#10/1989 Try here ... (but some numbers are a bit worrying in the descriptions 999c 1271cc ??) |
Author: | Kennomini [ Thu Sep 26, 2013 4:23 pm ] |
Thanks for that. Does anyone else have another source of info to cross reference? |
Author: | MiniVLT [ Thu Sep 26, 2013 4:28 pm ] |
Little bit of calculating to do: http://www.minimania.com/article/861/GE ... alculation Cheers Shane |
Author: | Kennomini [ Sun Oct 06, 2013 10:11 pm ] |
Still searching for gear set ratios. I found this website http://www.calverst.com/articles/Gearbo ... _types.htm dose the list of ratios half way down match what's avaliable in ozzy minis? |
Author: | MiniVLT [ Mon Oct 07, 2013 1:23 pm ] |
My gearbox ratios are the same as the 4 sync 850/998/1098 list. My casing is a 22G1832 & layshaft P/no is 22G297, with 31 26 21 17 tooth count. I'm pretty sure the gearbox came of a 998 originally too. Using my link above and knowing the above info plus the drop gears, that's what I came up with! It did help having the gearbox apart at the time. Cheers Shane |
