It is currently Mon Jul 21, 2025 1:36 pm
 Post subject: Missing compliance plate
PostPosted: Thu Sep 26, 2013 1:21 pm
Hi All.
I have a 1971 Mini Clubman which I bought as a partial resto - but it is missing the compliance plate from the body (i can see where it use to be attached). The VIN etc are on the old rego label - and no doubt the VIN would also be on the chasis somewhere.
What are my options in terms of either getting a replacement - or getting Vic Club plates without it?
Thanks, Paul.
1971 Clubman
PostPosted: Thu Sep 26, 2013 1:56 pm
The same numbers should still be be on the radiator shroud.
As the car has been registered in Oz before it should not be a problem. As it is NOT a VIN plate, it is an ADR compliance plate.
Standard 17 digit VIN plates started in 1980 (long after Oz Minis finished).
PostPosted: Thu Sep 26, 2013 2:07 pm
A missing compliance plate is not a reason to fail an RWC in Vic. See here under "Identification (Compliance) Plates / VASS Approval Certificates" on P10.
http://consult.vicroads.vic.gov.au/document/show/150
My Moke is a 71 and the compliance plate is missing too. Provided you have old rego papers or an old label so you can prove previous registration you will have no problems.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Sep 26, 2013 8:12 pm
If you have the details why not buy a new plate? They are available on fleabay and other places.
PostPosted: Thu Sep 26, 2013 8:27 pm
That is a build plate, not a compliance plate. Minis from 1970 had a compliance plate and nobody makes replicas.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Fri Sep 27, 2013 7:00 am
Time someone starts to make them then hey!
"Let us remove your "SHORTS"
PostPosted: Fri Sep 27, 2013 8:08 am
I think it might be naughty, because people could start creating their own Mini SS and 4 seater Californians!
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
