Missing compliance plate
https://www.ausmini.com/forums/viewtopic.php?f=2&t=82895
Author:  paulc8712 [ Thu Sep 26, 2013 1:21 pm ]
Post subject:  Missing compliance plate
Hi All.
I have a 1971 Mini Clubman which I bought as a partial resto - but it is missing the compliance plate from the body (i can see where it use to be attached). The VIN etc are on the old rego label - and no doubt the VIN would also be on the chasis somewhere.
What are my options in terms of either getting a replacement - or getting Vic Club plates without it?
Thanks, Paul.
Author:  drmini in aust [ Thu Sep 26, 2013 1:56 pm ]
Post subject:  Re: Missing compliance plate
The same numbers should still be be on the radiator shroud.
As the car has been registered in Oz before it should not be a problem. As it is NOT a VIN plate, it is an ADR compliance plate.
Standard 17 digit VIN plates started in 1980 (long after Oz Minis finished).
Author:  bnicho [ Thu Sep 26, 2013 2:07 pm ]
A missing compliance plate is not a reason to fail an RWC in Vic. See here under "Identification (Compliance) Plates / VASS Approval Certificates" on P10.
http://consult.vicroads.vic.gov.au/document/show/150
My Moke is a 71 and the compliance plate is missing too. Provided you have old rego papers or an old label so you can prove previous registration you will have no problems.
Author:  womble99 [ Thu Sep 26, 2013 8:12 pm ]
If you have the details why not buy a new plate? They are available on fleabay and other places.
Author:  bnicho [ Thu Sep 26, 2013 8:27 pm ]
That is a build plate, not a compliance plate. Minis from 1970 had a compliance plate and nobody makes replicas.
Author:  Convertible Mini [ Fri Sep 27, 2013 7:00 am ]
Time someone starts to make them then hey!
Author:  bnicho [ Fri Sep 27, 2013 8:08 am ]
I think it might be naughty, because people could start creating their own Mini SS and 4 seater Californians!
