It is currently Thu Aug 07, 2025 8:29 pm
 Post subject: Radio wiring
PostPosted: Wed Oct 02, 2013 6:32 pm
OK I decided it was time to put some tunes in the Mini
Sony exploit radio / cd player
Here's the weird thing
as per instruction and what little I do know
red to power supply off ignition
yellow to constant power for memory .straight to battery with inline fuse
black to earth , straight to battery because I have a isolator on the earth cable
With the isolator switch on [power connected ] radio works as it should , turns on and off . turn off key and radio turns off ,lock up car all good
open boot and isolate [negative] battery
Radio comes on :shock:
turn isolator back and radio goes off :?
WHY ?
Mark
 Post subject: Re: Radio wiring
PostPosted: Wed Oct 02, 2013 6:45 pm
Odd!
And will it then play normally with the negative isolated??
And is it remembering the time ok?
PostPosted: Wed Oct 02, 2013 6:51 pm
Hi Mick
yes it plays as normal
haven't set the time yet
I can turn it off on the radio , but not with the remote when its in isolate
Mark
PostPosted: Wed Oct 02, 2013 6:59 pm
Could you rewire the constant positive to the constant supply at the fuse panel?
I have an idea, but can't really confirm it.
You're certain however that the -ve is in fact going to the -ve terminal?
PostPosted: Wed Oct 02, 2013 7:12 pm
Yes , is negative side of battery ,
might run a dumby wire from the fuse box as you say and see what happens
worst part of it is, it is all mounted under the back seat ,
Mark
PostPosted: Wed Oct 02, 2013 7:35 pm
Have you got a car alarm or anything else that runs off the negative terminal like the radio?
PostPosted: Wed Oct 02, 2013 7:54 pm
I have an internal window aerial ,
earth wire from battery to aerial and radio only
+ve power to aerial comes from the radio when switched on [power aerial or aerial amplifier ]
the earth has a bare braided wire , which I soldered an extension onto to splice in with the radio earth
Might insulate the braided section , as it is sitting under the rear parcel self and maybe touching the body
No other items
PostPosted: Wed Oct 02, 2013 8:09 pm
I've had this where an artificial negative is created through another load. The voltage drop across the load creates an artificial negative. Wire each up separately and try them out on their own.
There may be a ground through the antenna too.
PostPosted: Wed Oct 02, 2013 8:36 pm
the radio body itself is not earthed , as it is mounted in a timber frame
do you think this may have something to do with it
it only has the earth in the wiring plug
Mark
PS should I move the isolator to the +ve side of the battery
I am running an alternator -ve earth
PostPosted: Wed Oct 02, 2013 8:43 pm
Its so hard to tell from here, a few minutes with a multimeter would show the problem. But go back to basics, wire the unit up from the dash without the yellow, and try from there.
PostPosted: Wed Oct 02, 2013 9:10 pm
Thanks Mick
I think I will start again from radio plug
RED +ve to switched power
BLACK -ve direct to -ve battery before isolator
YELLOW +ve direct to constant +ve side of battery
BLUE from radio +ve to aerial amp
BLACK extra -ve battery direct to radio body
BLACK extra -ve battery direct to aerial
Mark
PostPosted: Wed Oct 02, 2013 9:22 pm
When I did mine (Barney), I ran the yellow wire to +12V onthe fusebox, and put a 10A auto reset circuit breaker across the isolator switch on the battery -ve lead. This way there was no chance of backfeed with the isolator turned off.
If someone tried to key start it when isolated, the breaker tripped, so it wouldn't start anyway. If it tripped, the radio lost its memory, but in normal use there was no problem.
Last edited by drmini in aust on Wed Oct 02, 2013 9:33 pm, edited 1 time in total.
PostPosted: Wed Oct 02, 2013 9:25 pm
Hi Doc
my battery isolator is on the -ve side of my battery
Mark
PostPosted: Wed Oct 02, 2013 9:31 pm
slacko wrote:
Hi Doc
Mark
So is mine. :P
Radio will work with the isolator turned off but you cannot start the car.
PostPosted: Wed Oct 02, 2013 9:36 pm
well its got me stumped :D
Mark
Users browsing this forum: No registered users and 67 guests
