It is currently Sat Aug 02, 2025 12:51 pm
 Post subject: Door hinge removal
PostPosted: Sun Oct 06, 2013 8:46 pm
I'm having issues getting the top door hinge off, the bolt on the upper a panel closest to the door specifically. Has anyone got any tips or recommend a tool? I've had a 7/16 socket 1/4 drive with a uni joint but still cant manage the space to spin it off. I've done it on another car years ago and dont remember it being this annoying but maybe the brand of socket I used was smaller back then?
Any help appreciated.
 Post subject: Re: Door hinge removal
PostPosted: Sun Oct 06, 2013 8:51 pm
Spray some wd40 on the bolt and I usually use an open ended 7/16 spanner and turn very slowly flat by flat
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Oct 06, 2013 9:03 pm
I use a sidchrome ring/OE spanner with a bend in the shank and the ring bit severely thinned down. :P
PostPosted: Mon Oct 07, 2013 7:37 am
Very patiently with lots of swear words
PostPosted: Mon Oct 07, 2013 8:40 am
When I got my car, the nut was just sitting on the end of the thread. Obviously too hard for the PO.
Like Wombat, plenty of patience and an open ended spanner; twelfth of a turn, flip, twelfth of a turn, flip... Or a skinnier spanner.
Behold! The mighty 850!
PostPosted: Mon Oct 07, 2013 1:32 pm
I picked up at a Swap Meet some time ago a 1/4" square drive extension about 6" long but it is flexible ie it is made from a spring which I have found is excellent in getting into hinge nuts. It is a proprietary line but has no brand on it. Combined with a 7/16" x 1/4" drive socket they are small enough to get into even the top inner hinge nut.
John Sneddon
0408 431 807
1963 Morris Cooper
1965 Morris 850
1968 Morris Cooper S
PostPosted: Mon Oct 07, 2013 8:15 pm
Thanks guys for the replies.
Think I might remove the other nut then use the open ended spanner as suggested on the tight one . Might find an older spanner and grind it down a bit hoping a skinnier head will fit in easier. Patience is a virtue hey.
With reference to the flexible extensions is it like one of these John Sneddon:
I'd seen them about and thought they could be gold for some irritatingly located nuts on a mini.
