It is currently Thu Aug 07, 2025 12:27 am
 Post subject: Gearbox ratios?
PostPosted: Wed Sep 25, 2013 5:06 pm
What would be the gear ratios in a 1990 Rover mini Cooper, rod change box. (I believe the diff ratio is 3.1:1).
 Post subject: Re: Gearbox ratios?
PostPosted: Wed Sep 25, 2013 7:43 pm
http://www.goo-net-exchange.com/catalog/ROVER__MINI/#10/1989
Try here ...
(but some numbers are a bit worrying in the descriptions 999c 1271cc ??)
PostPosted: Thu Sep 26, 2013 4:23 pm
Thanks for that.
Does anyone else have another source of info to cross reference?
PostPosted: Thu Sep 26, 2013 4:28 pm
Little bit of calculating to do:
http://www.minimania.com/article/861/GE ... alculation
Cheers Shane
PostPosted: Sun Oct 06, 2013 10:11 pm
Still searching for gear set ratios. I found this website http://www.calverst.com/articles/Gearbo ... _types.htm dose the list of ratios half way down match what's avaliable in ozzy minis?
PostPosted: Mon Oct 07, 2013 1:23 pm
My gearbox ratios are the same as the 4 sync 850/998/1098 list.
My casing is a 22G1832 & layshaft P/no is 22G297, with 31 26 21 17 tooth count. I'm pretty sure the gearbox came of a 998 originally too.
Using my link above and knowing the above info plus the drop gears, that's what I came up with! It did help having the gearbox apart at the time.
Cheers Shane
