Hi,
I'm building an engine for a friends S. I'm a bit out of touch with a few things and would like some suggestions from those of you who have 'been there, done it and decided not to do it again because it didn't work."
Engine spec is
Thin flange 1275 block
Omega 1275 offset dish pistons at 60 over.
Stock S crank and rods, stock journals too, it was a low km car
Pierce head with non S type valves (small)
Titan belt drive
266 Kent cam
1.5 roller rockers
Maniflow 1 3/4 SU Manifold with twin HIF's
LCB Maniflow 1 3/4 with RC 40 system.
Light flywheel/pressure plate
It's a road car but not a daily. Trying to get to 100hp and still have an idle.
I will say the pierce head is not as good as I hoped. we bought it early on with little research. The inlet ports are too big and way too low (my opinion) Why they didn't lift all the ports up 15mm baffles me, the short side radius is not good. I've straightened out the casting lumps and made the best of a bad situation generally while trying to not enlarge the ports.
Questions areDistributor. what's a good pick? I have used Bosch units modified by Scorcher in Vic years ago, they can still make me one, is there a better option? No crank triggers, my life is complex enough.
Compression ratio. I'm thinking 10.5:1 with the alloy head. Anyone had experience with this?
Cam timing. Card says 106. Suggestions? Some say advance it up. Experiences?
I have a set of HS4 SU's and the HIF 1 3/4's. Debating if the bigger carbs will be the go?
I would ask GR but I, like him, run my own business and I have severe guilt in calling him up to waste his time when "we" didn't spend any money with him. I will get you to run it in on the dyno GR but I'd like to get it close on cam timing and ignition adjust-ability before hand.
