It is currently Sun Jul 20, 2025 12:37 am
 Post subject: Lower control arm
PostPosted: Tue Oct 22, 2013 7:45 pm
Hi I'm currently rebuilding my front subframe , I noticed my lower control arms threads were damaged and so can't put the nut back on , I've got a couple of spare arms but they are slightly different though the replacement arms I've got have a lip , there is a bit of a gap where the lip and subframe meet , just wondering if they are going to be ok to use or not?
Sent from my iPhone using Tapatalk - now Free
 Post subject: Re: Lower control arm
PostPosted: Tue Oct 22, 2013 7:53 pm
The one on the left in the top pic looks like some sort of modded home job.
It's still probably okay for use.
PostPosted: Tue Oct 22, 2013 8:22 pm
nah, it was standard on some models - I have them in my car (MK2 S)
PostPosted: Tue Oct 22, 2013 8:53 pm
The one on the left is standard Mini, the other one I suspect is early 850 (if the bolt is straight, as looks in the pic).
It is pretty normal for the flange to have a gap as shown. The flange aligns the bent type pivot bolt & stops it from turning, it has no other purpose.
PostPosted: Tue Oct 22, 2013 9:17 pm
Ok cool thanks for the replies guys :)
PostPosted: Wed Oct 23, 2013 1:27 pm
they`re all bent to clear the axles
& the early one is without the flange , the later type with the flange
