Rod change coupling and oil seal ( buy local) https://www.ausmini.com/forums/viewtopic.php?f=2&t=83202 |
Page 1 of 2 |
Author: | cush [ Mon Oct 21, 2013 9:02 pm ] |
Post subject: | Rod change coupling and oil seal ( buy local) |
( formerly the Rod change oil retention prevention system* thread) I know you can get a kit to stop this badboy from leaking, but what is the name of the metal part in the picture? ![]() I suspect this (and the pin) needs a replacement too. Cheers Oh and hi.. ![]() |
Author: | KLAS [ Mon Oct 21, 2013 9:41 pm ] |
Post subject: | Re: Rod change oil retention prevention system* |
42H1116 is its partnumber, called coupling or eye bold sleeve |
Author: | boomini [ Mon Oct 21, 2013 10:07 pm ] |
I would call that f#*cked.... wow never seen one that bad. How did you get gears |
Author: | Mokesta [ Mon Oct 21, 2013 11:09 pm ] |
Wrong Cush! You can buy a kit to slow that thing's leak. You cannot buy a kit to "stop" that thing from leaking. M Oh, and welcome back again. |
Author: | TheMiniMan [ Tue Oct 22, 2013 7:07 am ] |
i make new "Seal-bushes" for them Cush ![]() & yes these new ones are removable to enable the replacement of the inner oring ![]() & yes welcome back young fella ![]() N.B. Image display fixed - winabbey |
Author: | cush [ Tue Oct 22, 2013 7:22 am ] |
How might they work? Where to they fit..? What's it meant to look like? ![]() Sent from my Nexus 7 using Tapatalk |
Author: | drmini in aust [ Tue Oct 22, 2013 1:29 pm ] |
New couplings made in Oz and case hardened are available now from Mini King. |
Author: | cush [ Tue Oct 22, 2013 5:45 pm ] |
I'll have one of Matt's and one of the doc's... Sent from my Nexus 7 using Tapatalk |
Author: | cush [ Tue Oct 22, 2013 5:56 pm ] |
Frooooooooooooooomm.. Sent from my Nexus 7 using Tapatalk |
Author: | MiniBill [ Tue Oct 22, 2013 6:00 pm ] |
cush wrote: Frooooooooooooooomm.. Sent from my Nexus 7 using Tapatalk Ooops my bad ..... ebay http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1299291152 Cheers Bill |
Author: | cush [ Tue Oct 22, 2013 6:11 pm ] |
I thought I knew that logo.. It's wood and Pickett. Now I know.. I might even change the subject... Sent from my Nexus 7 using Tapatalk |
Author: | mini_mad_matt [ Tue Oct 22, 2013 6:12 pm ] |
Personally i think Matt's seal is much better then that ebay one. Just knock it in first and then a plain old oil seal and it shouldn't leak again. |
Author: | cush [ Tue Oct 22, 2013 6:22 pm ] |
Post subject: | Re: Rod change coupling and oil seal ( buy local) |
You crazy Matthews must stick together... http://minisport.com.au/prod593.htm I'm assuming Matt (Read) your bit replaces the metal part of the above kit? Sent from my Nexus 7 using Tapatalk |
Author: | awdmoke [ Tue Oct 22, 2013 6:41 pm ] |
It does. And it works. I got a couple of these off Matt about 6 or 7 years ago, still going strong. You need to use an ordinary seal too. The hard part is getting all the old ones out. |
