Paint Stripping and other restoration woes https://www.ausmini.com/forums/viewtopic.php?f=2&t=8322 |
Author: | redfive [ Tue Jun 21, 2005 8:44 pm ] |
Post subject: | Paint Stripping and other restoration woes |
I thought I'd start a thread on paint stripping, cos I couldn't find one. I've taken this week off to prep my mini for the paint shop and am currently stripping the paint off it. What methods to people like to use? So far I've been through over 4 litres of paint stripper, and I've still got a lot of the interior to go. Next stage is sanding it smooth and clean. I've got an orbital sander, one of the square types. All the guides I've read recommend a dual action sander, is this the round orbital ones which also spin? Do I get a fast rotation one or a slow rotation one and can anyone recommend appropriate sand paper grades to use? What grit should I use? If anyone has a step by step restoration guide I'd love to read it. While I'm at it, does anyone have any tips for removing the fuel tank. My tube spanner is slipping on the drainage nut on the bottom, so I can't get the tank out. I'm also having trouble getting the windows out of the door. The manual says to remove the door hand mechanism, but I'll be damned if I can get it off the rail, and I can't move the divider to get the window out. Cheers, Richard |
Author: | simon k [ Tue Jun 21, 2005 9:31 pm ] |
Post subject: | Re: Paint Stripping and other restoration woes |
redfive wrote: Next stage is sanding it smooth and clean. I've got an orbital sander, one of the square types. I'm using a wire brush on my angle grinder - I did the front-end of my deluxe last night and it's got all the junk off after paint stripper.... redfive wrote: If anyone has a step by step restoration guide I'd love to read it. you and me both... JAM's site has some handy tips.... www.justanothermini.com redfive wrote: While I'm at it, does anyone have any tips for removing the fuel tank. My tube spanner is slipping on the drainage nut on the bottom, so I can't get the tank out.
if you can't get a 7/16 spanner on there, do what I did and put a pry bar underneath the tank, lift enough so that the tube and nut come up through the hole, if you still can't undo it, use a chisel or screwdriver to break the tube off, then fix any dents you made with the pry bar ![]() ![]() can't help with the windows, I'm leaving mine in... Simon |
Author: | 1380 yellow devil [ Tue Jun 21, 2005 9:41 pm ] |
I have removed my windows before they are apin to do as I had to repalce the Quarter Glass, Just make sure you losen the screws that are around the toop of the Window frame that hold on the metal strip for the quarter glass. I had some trouble when I did my fisrt one But now it is all easy and I have repalced the winder twice and each time i did it wuicker then before. Do not be ruoght but take your time and you will get them out. |
Author: | FIGJAM [ Tue Jun 21, 2005 10:15 pm ] |
I bought a really good book the other day called practical classics,Mini Cooper Restoration.Published by Kelsey Publishing LTD,1997. It has good tips on buying and restoring older cars. Editor was Peter Simpson and I got it from a car bookshop in Claret St ( I think) Sydney for around $30. |
Author: | FIGJAM [ Tue Jun 21, 2005 10:33 pm ] |
Just found the sticker.Auto Book World, ph:(02)9299 6669,Cost was $34.95 |
Author: | redfive [ Wed Jun 22, 2005 7:01 pm ] |
Thanks for the advice all. Got the fuel tank out using my tube spanner, a rightangle screwdriver and a bit of an extension bar. It took quite a bit of force ![]() Got one window out as well. Ended up having to use a hammer to budge it. Gotta get the handle off the door now, the outside one. Next time I restore a mini, I'm going to pay someone else to do it ![]() |
Author: | Besser [ Wed Jun 22, 2005 9:03 pm ] |
Post subject: | Tut Tut Simon |
Simon bet you didnt use a pry bar on the cooper did you? Hey I used a hatchet on the blue cooper I got from you but thats another story. Try roughing befor paint stripper. I use a 20or 40 grit pad on a low speed 9" disk. Run it all over the panel then apply the stripper. you can see the scratches letting the striller get under the paint. |
Author: | simon k [ Wed Jun 22, 2005 11:22 pm ] |
Post subject: | Re: Tut Tut Simon |
Besser wrote: Simon bet you didnt use a pry bar on the cooper did you? Hey I used a hatchet on the blue cooper I got from you but thats another story.
Try roughing befor paint stripper. I use a 20or 40 grit pad on a low speed 9" disk. Run it all over the panel then apply the stripper. you can see the scratches letting the striller get under the paint. nah, not on my cooper - just the little deluxe.... there are at least 6 coats of paint on it - I've got my work cut out |
Author: | Harley [ Thu Jun 23, 2005 12:35 pm ] |
Brake fluid takes everything straight off in one go! Happened on my firewall when the cap came off. |
Author: | MiniK [ Thu Jun 23, 2005 1:56 pm ] |
Try roughing befor paint stripper. I use a 20or 40 grit pad on a low speed 9" disk. Run it all over the panel then apply the stripper. you can see the scratches letting the striller get under the paint. Using the sand paper first is the best idea..my brother is currently doing that on his Capri and it works well.... Alternatively use poly stripper from the hardware shop....takes a while to work(overnight is usually good) but it does a damn good job ![]() |
Author: | drmini in aust [ Thu Jun 23, 2005 8:09 pm ] |
Another good trick with paint stripper is bung it on then cover it with gladwrap. That way it attacks the paint better, instead of evaporating.. ![]() |
Author: | GT1360 [ Thu Jun 23, 2005 8:13 pm ] |
I am with you on the Drmini.. I did that with evil.. It worked a treat.. I took a pic of it 2.. ![]() ![]() |
