New suspension for the leyland. What do you run ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=83221 |
Author: | Bennjamin [ Wed Oct 23, 2013 1:51 pm ] |
Post subject: | New suspension for the leyland. What do you run ? |
Hey team , thought I'd run this past here and see what local guys are running on their minis for both daily and track/hillclimb/etc What do you lot run or recommend for shocks? What about rubber cones- oem , red or yellow dot ? Interested to see what setups are here on Aussie roads cheers |
Author: | Bennjamin [ Wed Oct 23, 2013 1:52 pm ] |
Post subject: | Re: New suspension for the leyland. What do you run ? |
PS I will be running original hi lows and will mostly have the car alittle lower than standard |
Author: | mezz [ Wed Oct 23, 2013 11:40 pm ] |
Hi there, Im running the red dots, and they are a bit stiffer than the original cones, however in using them for over 3 months i have found them satisfactory. In any case i did try out the coilovers and have to say didnt enjoy the ride one bit, too stiff and not enought wieght in the back causing it to bounce around. |
Author: | Bennjamin [ Thu Oct 24, 2013 7:08 am ] |
Thanks for the reply Yeah looking at red dots, what shocks do you run? Lowered at all? I haven't considered proper coil over suspension at all, the geometry just doesn't look right in place of the shocks ! Plus I've heard its bouncy and requires much more setting up |
