Pre Verto clutch adjusting https://www.ausmini.com/forums/viewtopic.php?f=2&t=83234 |
Author: | bill.b [ Thu Oct 24, 2013 6:10 pm ] |
Post subject: | Pre Verto clutch adjusting |
Hey Guys, I just wanted to adjust my clutch as it was proving harder to put into first and reverse when stationary,I was having a read of a few of the mini manuals and I have figured out i have the pre verto clutch with no throw out stop bolt. I was attempting to adjust the adjustable stop and the process appears to have worked, i took the lock nut back a few turns and then the stop nut out a few turns and locked it back up. it all appears to work however i don't fully understand how i am suppose to have a gap of 1.5mm between the arm and the stop nut, the arm will just naturally fill the space. I made sure i hadn't done it wrong by screwing the stop nut in until i achieved this gap but the clutch was useless and just pressed straight to the floor. So i wound it back out and set it up and it works really well now but is this right????? how do i know the clutch release bearing is not rubbing hard on the clutch thrust plate ????? Thanks, Bill |
Author: | simon k [ Thu Oct 24, 2013 7:08 pm ] |
Post subject: | Re: Pre Verto clutch adjusting |
take the spring off before you adjust it - and 1.5mm is too much, book says .020", which is .5mm remove spring, pull the arm out by hand, measure, adjust, repeat |
Author: | bill.b [ Thu Oct 24, 2013 7:16 pm ] |
ahhhhh i didn't take the spring off!! ![]() ![]() ![]() Thanks Bill |
Author: | mini_mad_matt [ Thu Oct 24, 2013 7:25 pm ] |
Having a larger gap just requires more pedal travel before actuating the clutch as the spring will pull the bearing further away from the clutch. |
Author: | bill.b [ Thu Oct 24, 2013 8:31 pm ] |
Ok fantastic, thanks. |
Author: | 1071 S [ Thu Oct 24, 2013 9:43 pm ] |
After many years using a spring I have taken Doc's advice and removed it. Feels fine but I reserve the right to curse him when the bearing collapses (prematurely, in my opinion ![]() Cheers, Ian |
Author: | drmini in aust [ Fri Oct 25, 2013 7:18 am ] |
1071 S wrote: After many years using a spring I have taken Doc's advice and removed it. Feels fine but I reserve the right to curse him when the bearing collapses (prematurely, in my opinion ![]() Cheers, Ian Rovers with Verto clutch use the same self-adjusting system, there is no spring, and they still use a ball thrust release bearing (not a carbon ring like some cars). Mine is still fine, using an RHP later type bearing. If/when? it ever dies I have a new Timken flat one to replace it. ![]() |
