Wanted to borrow in Perth, Primary gear removal tool?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=83239
Author:  Candy [ Fri Oct 25, 2013 12:01 am ]
Post subject:  Wanted to borrow in Perth, Primary gear removal tool?
Hi all,
It has been some time since I've been here, or worked on my mini. I have to replace my primary gear oil seal, and need to pull out the primary gear. Does anyone have a primary gear removal tool and the seal installation tool to stop the splines wrecking my new seal again tha they feel like lending for a few hours?
Any help would be appreciated.
Regards, Ray.
Author:  boomini [ Fri Oct 25, 2013 7:44 am ]
Post subject:  Re: Wanted to borrow in Perth, Primary gear removal tool?
Welcome back ray. Good to see another perth user.
Cant help you out tho sorry. Nit sur what the tools look like but could you not wrap electrical tape over the splines and use plenty of grease to put the seal in.
Rodney
Author:  drmini in aust [ Fri Oct 25, 2013 9:04 am ]
I use a 3 leg puller to remove the primary gear + seal in situ.
I thinned the feet of the legs 3 down to grip in behind the splines, and I put a thick cable tie round them before winding it out.
Author:  Candy [ Fri Oct 25, 2013 9:36 am ]
Cheers doc, might need to give that a go.
Author:  Minute [ Fri Oct 25, 2013 10:17 pm ]
Hi Ray,
Ive a Primary Seal Installation sleeve I can lend you. Im not too far away either. Number is 0403 784 218
Claeten
