It is currently Sun Jul 20, 2025 8:31 am
 Post subject: wheel bearing issue!
PostPosted: Mon Oct 28, 2013 9:27 pm
according to the mini parts shops in England the tapered wheel bearing does not fit a drum brake car! are our minis different? if any one knows the correct answer i would be very gratefulll!!!!!!!!!!!!!!!
 Post subject: Re: wheel bearing issue!
PostPosted: Mon Oct 28, 2013 9:38 pm
They are totally wrong. Which shop was this?
Ball bearings and Timken tapered rollers are exactly the same outside diameter and are 1.250" bore.
The difference between a drum braked mini and a Cooper S disc braked one is the bearings fit on the drive flange with drum brakes, and on the CV with discs (7.5" or 8.4").
Timkens fit in drum brake Minis, no problem. :wink:
PostPosted: Mon Oct 28, 2013 9:40 pm
I can't say for all minis, but I was pretty sure that the bearings from drum brakes minis were the same as the discs. The cv joint are different however (unless you have the 7" discs I believe).
On another note, genuine timken bearings are supposed to be the best - the others can have the wrong preload.
-- Looks like the doc beat me to it. Hey, I was right :D
PostPosted: Mon Oct 28, 2013 9:43 pm
thanks for the info !
