I'll put the kettle on.
Might be worth checking your knuckle joints and cups. If they've been squeaking, or sitting for a long time, chances are you need new ones - that can make your car sit low, and depending on the model we may not be able to correct that just by increasing the pressure. We can pack the knuckle shaft for height, but it's also important that the joint/cups are in similar condition on each side (eg both fronts are the same and both rears).
If you drive 'enthusiastically' I recommend you get at least front, and if you can also the rear comp bump stops - cuts roll dramatically, at the expense of a stiffer ride. On Min, I have these and fully adjustable suspenders front and rear - antiroll bars at both ends and shockies on the front. Add 6" minilites and sticky Dunlops and she sticks to the road like gum on your shoe.
It's also likely you'll need a front alignment afterwards...all fun and games, but at least no %$##@ing computers, OBDs etc YAY! (and a well adjusted hydro car is a joy to drive)
_________________ Min - 1970 MkII S, 119hp Dave Anton 1380, SH Engineering belt drive, 1.5 rollers, 123Tune ignition, 48 DCO SP Weber, HP Headers, MSD, Maniflow ex. Swiftune SC/CR 3.7 + ATB, all KAD front, antiroll bars and gas shocks, 6 inch Minilites with Dunlop Sports
