replacing rear drums with new all-in-one kit. Easy?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=83296
Author:  Bennjamin [ Tue Oct 29, 2013 6:17 pm ]
Post subject:  replacing rear drums with new all-in-one kit. Easy?
Hey everyone
Just after an idea here - i have a couple of drum backing plates setup ready to install on my mini.
Ive noted you have to remove the rear outer hub but are the existing bearings reused / touched/ removed at all ? Should i replace the rear bearings ? Thinking of ordering them with the next UK shipment if need be
Whats the basic process ?
Thanks !
Author:  Mick [ Tue Oct 29, 2013 8:25 pm ]
Post subject:  Re: replacing rear drums with new all-in-one kit. Easy?
Yes the bearing will need to come off with the hub. They usually come off without a drama.
If they come off without a fight, and are carefully removed and replaced in the same order and without any dirt, then they will be perfectly fine.
If you need to remove the bearing with a puller or using a drift, then you should replace it.
Author:  simon k [ Tue Oct 29, 2013 8:35 pm ]
I like to wash them in turps and repack them with new grease...
Author:  mickmini [ Wed Oct 30, 2013 3:57 pm ]
white spirit is the best thing to remove the old grease
Author:  Mick [ Wed Oct 30, 2013 4:39 pm ]
Why is that Mick? What does white spirit offer?
I've always wondered why there is so much of it on the hardware shelves..
Author:  Bennjamin [ Wed Oct 30, 2013 5:40 pm ]
white spirits is turps....isnt it ?
Anyway ill grab some new rear bearings from minisport as they are cheap and might be needed.
Author:  simon k [ Wed Oct 30, 2013 6:35 pm ]
probably... shops put both of them on the shelf so you think you need a bottle of each
