It is currently Sat Jul 19, 2025 9:37 pm
PostPosted: Mon Nov 04, 2013 5:53 pm
Evening I'm currently looking at buying one of those 4 pot caliper kits from the uk( see links below)for a Xmas present for my car, but I'm concerned that what l will order will either be wrong or not have all the required parts required to fit over the Xmas break. The car is a clubman running coopers discs/ calipers ATM. Can members who have fitted one oft these kits or similar,please leave positive/ negative feedback? Was it a worthwhile upgrade and was it a easy install. Thanks again.
http://www.kentautodevelopments.com/sho ... -disc-7.75
http://www.minispeed.co.uk/content/75in ... it-stage-2
1993 R32 Nissan Skyline GTR
PostPosted: Mon Nov 04, 2013 6:39 pm
I bought a kit from minisport once that had incorrect parts with it and it was a complete nuisance to try and get it changed. Now I buy these kits http://www.minisport.com/mini-sport-x-d ... ipers.html fully assembled ready to just bolt on. Have never had a problem with these, have fitted at least 6 sets I can think of off the top of my head.
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Nov 04, 2013 6:47 pm
I too have purchased a 7.9 inch 4 pot kit from minisport.com - I asked in advance if they fit my 10 inch rims and they do :)
Basically complete bolt on ( with disc CV's )
Refer to my build thread for some pictures
viewtopic.php?f=3&t=82960&start=15
PostPosted: Tue Nov 05, 2013 10:31 pm
i bought a kit from minisport 8.4" completely assembled as like yourself wasnt sure on what i needed to buy it individually, also minisport were really helpful in what rims fit the caliper size
PostPosted: Wed Nov 06, 2013 3:12 pm
I bought the kit from Minisport - been a hassle. Ball joints were so tight they couldn't be moved - had to re- shim. The ball joints are also classed as after market - got in some "genuine" from Minispares but can't tell the difference - both hard to file etc (had some genuine from Minispares from about 5 years ago looked totally different BUT easy to mark with file ? )
Latest hassle is the steering arm is for a pommy steering rack - has a different angle to the Ozzie one and a different size hole for the steering rack ball joint pin. :evil:
Only went with Minisport was 1 - ready assembled and bolt in (Ha!)
2 - Minipares were out of stock of some components at the time
Knowing what I know now I would get the kit ( unassembled as they do it) from Minispares and make sure you get the right steering arms. ( and an extra packet or two of shims :wink: )
David L
PostPosted: Thu Nov 07, 2013 7:43 am
The steering arm should have the same size hole whether early type or UK Mk2 on.
As for the balljoints if you CAN'T file the threaded end I would NOT use them, they are dangerous. The thread should be relatively soft.
PostPosted: Thu Nov 07, 2013 10:16 am
OK. - I'm confused ( easy for an old bloke) I have 3 sets of ball joints - all un-used two I can scratch a shallow mark with a V file and make a mark I can catch my fingernail on the on the other I can gouge a screwdriver slot nearly with the same effort .
Which do I use?
(Thought I had to use the harder one?)
David L
PostPosted: Thu Nov 07, 2013 11:07 am
If you are going to be buying a bit of stuff from minispares, go over to theminiforum.co.uk and sign up as a TMF+ member. If you link that account to your minispares account you'll get 7.5% off all purchases.
It does cost 5 pounds, but buying a 500 pound brake kit would net you a saving of 37 pounds...
PostPosted: Thu Nov 07, 2013 12:56 pm
Which do I use?
If you are talking the threaded end, all 3 are OK.
But if you can file a flat on the outside of the ball end, they are too soft.
ps. grind a small flat (~1.5mm wide)in 1 spot on the ball OD to let the grease through, if it doesn't have one.
PostPosted: Thu Nov 07, 2013 3:04 pm
Ah...I see said the blind man as he picked up the hammer and saw.
David L
PostPosted: Thu Nov 07, 2013 5:16 pm
Good to know!
Users browsing this forum: Bill B and 72 guests
