smiths temperature gauge https://www.ausmini.com/forums/viewtopic.php?f=2&t=83375 |
Author: | mad-mk1 [ Wed Nov 06, 2013 4:20 pm ] |
Post subject: | smiths temperature gauge |
hey gurus, i believe im in a pickle. well i think i am anyway. i have an aftermarket loom (classicwiring looms) which adds a few extra things (immobilizer etc) and does away with a few things. leaving me with headlight relays and a blade fuse box etc. i am running classic gauges all smiths, and im wondering about wiring up the temperature gauge. how would i go about it? the places i have read, tell me to take 10v from the voltage stabilizer to one pin on the gauge and the other too the sender. could i just take 12v from the fuse box, and i would likely need a resistor or something? sorry for the dumb questions! cheers jamie |
Author: | minijcar [ Wed Nov 06, 2013 5:52 pm ] |
Post subject: | Re: smiths temperature gauge |
No The voltage from the regulator is regulated not dropped to provide a constant 10v to the gauge. If you did it the other way the reading would fluctuate as the battery voltage fluctuated. ![]() |
Author: | Mick [ Wed Nov 06, 2013 7:17 pm ] |
minijcar wrote: No The voltage from the regulator is regulated not dropped to provide a constant 10v to the gauge. If you did it the other way the reading would fluctuate as the battery voltage fluctuated. ![]() As well, you can't judge the amount of current the gauge consumes as it changes with temperature, so the resistor would be at best a guess, and not represent the correct reading across the range. |
Author: | minijcar [ Wed Nov 06, 2013 7:52 pm ] |
Ohms law |
Author: | mad-mk1 [ Wed Nov 06, 2013 7:56 pm ] |
My issue is I don't use the voltage stabilizer, unless I have missed something when it was wired |
Author: | phillb [ Wed Nov 06, 2013 11:08 pm ] |
mad-mk1 wrote: My issue is I don't use the voltage stabilizer, unless I have missed something when it was wired Your standard fuel gauge should also be running off the voltage stabiliser. I would recommend an electronic stabiliser instead of the old original one too. |
Author: | mad-mk1 [ Thu Nov 07, 2013 7:59 am ] |
Ok looks like I need to do some more research into this. Where would you start with an electronic one? |
Author: | drmini in aust [ Thu Nov 07, 2013 8:40 am ] |
mad-mk1 wrote: Ok looks like I need to do some more research into this. Where would you start with an electronic one? PM Wombat, he makes em cheap with 3 flying leads so you just hook up as per usual. I can't remember what the chip is.. Can either put it in the original can or just hide it in the wiring. |
Author: | S_Squirel [ Thu Nov 07, 2013 8:48 am ] |
L78 10 CV L78 3 pin regulator 10V constant http://www.ebay.com.au/itm/L78xx-Series ... 2ecb188cc0 Cheers |
