Can a 1275 Flywheel be lightened? https://www.ausmini.com/forums/viewtopic.php?f=2&t=83379 |
Page 1 of 2 |
Author: | idr17 [ Wed Nov 06, 2013 11:17 pm ] |
Post subject: | Can a 1275 Flywheel be lightened? |
I have a standard 1275 (22lb) flywheel and was wanting to lighten it to at least stock Cooper S (18lb). It will installed in a MK2 Cooper S. I have read where this can be an issue given the flywheel is cast. Is this correct; or can it be lightened? |
Author: | justminis [ Thu Nov 07, 2013 7:19 am ] |
Post subject: | Re: Can a 1275 Flywheel be lightened? |
Yes, cast flywheel can be lightened, easiest way will be to face .200" off the non-clutch plate side and then make up 3 x .200" spacers to go under the straps, still using the original washers. Should also check that your diaphragm is set up properly. And, yes, flywheel will need to be re-balanced after lightening. |
Author: | drmini in aust [ Thu Nov 07, 2013 7:23 am ] |
Sure it can be done, I do it to both the 1 piece and 2 piece flywheels. Just don't touch the hub area. For road use I face .200" off the outer face, down to 1/4" from the thick tapering bit near the hub. Then I face another .120" off, just down to the 3 slots. The straps need .200" thick machined spacers fitted to put them at original height. Vizard's HTMYM book shows metal taken off the inside face too, below the ring gear- but I don't bother. Stock Deluxe or Cooper S 2 piece flywheel, or Mini 1 piece is ~7.4kg. The Morris 1100S one is heavier. Weight of mine after machining above is 6.0kg. Other folks drill big holes around them too, but I don't bother for a road car. If I'm changing the ring gear, I go for the 3/8" wide one as it's lighter. After machining the flywheel MUST be balanced, as grey cast iron is not homogenous. |
Author: | simon k [ Thu Nov 07, 2013 2:26 pm ] |
Dr Mini, do you have a picture of one you've lightened side-by-side with a standard 1100S? |
Author: | drmini in aust [ Thu Nov 07, 2013 3:04 pm ] |
simon k wrote: Dr Mini, do you have a picture of one you've lightened side-by-side with a standard 1100S? I have a standard 1098 one, not an 1100S. I also have a lightened one I've just done, can take a pic, it used to be an 1100S one... If anyone has a stock heavy 1100S one please one put a pic up, and I'll add mine. |
Author: | bluewhitecoopers1968 [ Thu Nov 07, 2013 4:05 pm ] |
Don't forget the back plate, good weight savings there too eh Sent from my iPhone using Tapatalk |
Author: | idr17 [ Thu Nov 07, 2013 4:21 pm ] |
Great thanks for the info guys, appreciate it. |
Author: | drmini in aust [ Thu Nov 07, 2013 4:58 pm ] |
bluewhitecoopers1968 wrote: Nowhere near what you can get off the flywheel. Flywheel weights- 1 piece stock = 7.4kg 1 piece DrMini lightened = 6.0kg 2 piece stock = 7.1kg 2 piece 1300 stock = ? bloody heavy! 2 piece DrMini lightened = 6.0kg Backplate stock = 2.5kg Backplate QH triangular = 2.0kg DrMini triangular lightened = 2.0kg Backplate 22G270 faced off to 7.5 thick = 1.9kg (was in miniDave’s 1293 but I took it out) too thin to trust... they are NOT steel. I don't lighten backplates- it takes far too long milling the outer shape manually, maybe worth it if you have a CNC mill. I did a few triangular Mazda rotor shaped ones on a lathe where I worked last, that took a lot of setting up on a faceplate 3 times. Not worth it, takes too long. IMO if you want a real light (and safe!) backplate go buy a steel one from UK. |
Author: | bluewhitecoopers1968 [ Thu Nov 07, 2013 5:04 pm ] |
I did, actually the whole assembly from Med. just giving options in case the dude didn't have 350 pounds plus postage to spend ![]() Sent from my iPhone using Tapatalk |
Author: | Phat Kat [ Thu Nov 07, 2013 7:08 pm ] |
drmini in aust wrote: Backplate 22G270 faced off to 7.5 thick = 1.9kg (was in miniDave’s 1293 but I took it out) too thin to trust... they are NOT steel. They're not steel, that's true. They're HSCI. I wouldn't go crazy lightening the other vatiety, but these ones can handle having more removed. For the time v's results... It's more effective to buy an after market Flywheel and Backing Plate in any case. |
Author: | drmini in aust [ Thu Nov 07, 2013 8:48 pm ] |
Phat Kat wrote: drmini in aust wrote: Backplate 22G270 faced off to 7.5 thick = 1.9kg (was in miniDave’s 1293 but I took it out) too thin to trust... they are NOT steel. They're not steel, that's true. They're HSCI. I wouldn't go crazy lightening the other vatiety, but these ones can handle having more removed. 22G270 S backplate is SG (spheroidal graphite) cast iron. Yes, stronger than grey iron, but not strong enough for a rally motor with an orange dot clutch when they are thinned down to 7.5mm thick, like this one was by somebody. ![]() |
Author: | miniDave [ Thu Nov 07, 2013 8:57 pm ] |
I think I have photos of the clutch bits Kev if you want them included here? |
Author: | Phat Kat [ Thu Nov 07, 2013 9:38 pm ] |
drmini in aust wrote: Phat Kat wrote: drmini in aust wrote: Backplate 22G270 faced off to 7.5 thick = 1.9kg (was in miniDave’s 1293 but I took it out) too thin to trust... they are NOT steel. They're not steel, that's true. They're HSCI. I wouldn't go crazy lightening the other vatiety, but these ones can handle having more removed. 22G270 S backplate is SG (spheroidal graphite) cast iron. Yes, stronger than grey iron, but not strong enough for a rally motor with an orange dot clutch when they are thinned down to 7.5mm thick, like this one was by somebody. ![]() Yeah they probably won't like that much ![]() ![]() |
Author: | drmini in aust [ Thu Nov 07, 2013 10:01 pm ] |
The one in my 1360 is a 22G270, it came out of a track car, it was milled out on a rotary table, in between the 3 lugs. After all that work by somebody it is only .5kg lighter, but it's all off the outside which is good. I'll put some lightened flywheel & backplate pics here tomorrow. |
Author: | drmini in aust [ Fri Nov 08, 2013 10:52 am ] |
![]() IMGP2692 by k_green1310, on Flickr Left flywheel one of mine, middle one is stock, right one is a Lynx Engineering milled flywheel from the 60s. ![]() IMGP2693 by k_green1310, on Flickr Left backplate is stock (2.5kg), middle one is the over-lightened 22G270 (1.9kg), right one is a Quinton Hazell backplate (2.0kg). |
